#1 Posted : Tuesday, 30 August 2005 7:53:52 PM(UTC)
Hi you guys no more than me thats for real.
Im in new zealand and im putting a 350chev into my HQ sedan.
I brought some mounts second hand and they look professonal
but now the fuel pump hits the power steering box.
Do I have the wrong mounts?? my engine is 1969
Ive also got a th400 trans will my standard cross member fit under it and bolt on or do I have to alter it.
I notice it has 2 sets of holes .
My HQ was a factory 202. Check it out here
http://www.geocities.com...ithholden/HQholden.html
Cheers in advance
#2 Posted : Tuesday, 30 August 2005 8:14:23 PM(UTC)
i put a t400 in a hz on a 4spd/trimatic crossmember just had to lengthen the bolt holes a bit. not sure bout the fuel pump, but hq's were designed for 350 chev's so it may be the mounts :?
keithholden Offline
#3 Posted : Wednesday, 31 August 2005 2:08:57 AM(UTC)
keithholden
I just registed so i can recieve emails etc
#4 Posted : Wednesday, 31 August 2005 3:16:53 AM(UTC)
You've probably got HK/T/G mounts. You need adapters for HQ-WB. Have a look at www.rodshop.com.au.
For the crossmember just find a HJ-HZ 308 auto sedan/wagon/statesman (not late HZ with TH350) and get it's crossmember. Get it's tailshaft too if it's a Se
jabba Offline
#5 Posted : Wednesday, 31 August 2005 3:53:42 PM(UTC)
jabba
I have a HQ ute with SBC and turbo 400. The fuel pump clears the steering (depending on outlet direction) with non-power steering. I briefly fitted power steering, and has to alter the fuel fitting placements on the pump (the bowl unbolts and can be mo
#6 Posted : Wednesday, 31 August 2005 4:53:16 PM(UTC)
Hi Keith.
As Byron said, you're better off using the HQ type mount adaptors.
The trick is they are different sizes & can be swapped. The thicker one goes to the driver's side.
Dr Terry.
#7 Posted : Wednesday, 31 August 2005 6:53:18 PM(UTC)
Hi Guys,
after reading this thread again i just realised i have a 202 with HQ/Z engine mounts sitting in a HT...but the motor just slotted straight in...parked right next to it for comparison is my 186HK and the 2 motors don't look like they're positione
#8 Posted : Wednesday, 31 August 2005 7:36:23 PM(UTC)
and the trimatic is on a HQ/Z mount as well...
there are no stupid questions, only stupid people
#9 Posted : Thursday, 1 September 2005 3:19:51 AM(UTC)
6cyl engine stuff is the same, but it is a bit difficult to compare transmissions between HK and HQ as the only one that is common is the optional (in HK) 3-speed all syncho, plus HK's mount very differently to HT/G/Q - the gearbox mounts like the early c
jabba Offline
#10 Posted : Saturday, 3 September 2005 4:05:22 AM(UTC)
jabba
Have just taken the pics and sent them through to keithholden. The mounts look to be identical side to side.
If anyone else is after them, let me know.
j
#11 Posted : Saturday, 3 September 2005 10:01:11 AM(UTC)
#12 Posted : Monday, 5 September 2005 4:02:58 AM(UTC)
HK and HT/G crossmembers are as alike as Valiant and Porche ones. They are totally different. HT/G crossmembers mount on outriggers off the front subframe. HK ones mount onto the floor underbody crossmember. Having said that, if you use a HT front clip on
keithholden Offline
#13 Posted : Wednesday, 7 September 2005 5:49:31 AM(UTC)
keithholden
UPDATE the mounts ive got are 2 parts one part has a angle and if the angle is at the front the engine is forward and if the angle is at the back(by swapping with the other side) the engine is about 20mm back.
I changed sides and looks like my fuel pum
This page was generated in 0.095 seconds.
