View Thanks
#1 Posted : Tuesday, 6 September 2005 7:13:05 PM(UTC)
Is it normal on all VN's that the brake pedal travel is nearly half way down before engaging. I'm asking for my father, who has a VQ Caprice and is the same (brakes) as the VN I used to own. He's been annoyed since he had the car, although the brakes work fine.
Cheers.
#2 Posted : Tuesday, 6 September 2005 7:54:21 PM(UTC)
start with a brake fluid change, checking for leaks etc and go from there. Old fluid or air in the system will cause a low pedal.
#3 Posted : Wednesday, 7 September 2005 7:58:43 PM(UTC)
I'm thinking it's just the way they are for those models. Both mine & my father's were reguarly serviced, including brakes, and they stayed the same. I suppose he'll have to live with it.
Cheers.
#4 Posted : Thursday, 8 September 2005 5:07:24 PM(UTC)
Replace the cups & rubbers in the master cylinder.
There is a fine "O" ring in the centre of both pistons, and this can wear out fairly quickly or become distorted over a reasonable period of time.
