#1 Posted : Wednesday, 7 September 2005 8:59:44 AM(UTC)
i am told that you can put powersteering into an hj just bolt the pump in is this correct?
#2 Posted : Wednesday, 7 September 2005 9:16:35 AM(UTC)
Short answer - yes, sort of.
Slightly longer answer (should hopefully answer most or all your questions)...
The box and pump are the same for 6 and V8. The brackets for V8 and 6 are extrememly different. Make sure you get ALL the bolts and spacers,
Munromad2004 Offline
#3 Posted : Wednesday, 7 September 2005 9:14:32 PM(UTC)
Munromad2004
I have just picked up a complete power steering set up from a HJ Statesman to fit to my HQ Monaro.
I don't have the steering arms.
Are they available to buy or is a wrecker the best option.
Anyone know what they are worth?
#4 Posted : Thursday, 8 September 2005 1:41:45 AM(UTC)
Best bet is to post a wanted to buy post in the sale/wanted section, if someone can tell us the length of them (power and manual) I've got some left overs from a HJ in the shed but I can't remember if it was manual or power....came as wreck about 10 years
#5 Posted : Thursday, 8 September 2005 4:29:03 AM(UTC)
Hi Guys.
The steering arms on the HQ are the same as any HJ/X/Z/WB with power steer. You don't need to change them.
#6 Posted : Thursday, 8 September 2005 5:04:22 AM(UTC)
but is there a diff in arm length with power and manual steering?? eg: the HJ's.......
life's to short not to be....
#7 Posted : Thursday, 8 September 2005 6:09:56 AM(UTC)
Thanks for clarifying my answer about the steering arms Dr Terry....I just re-read my post and I could have worded that bit somewhat better.
All HQ and the HJ-WB power steering arms are about ¾" - 1" shorter in length (from front bolt to Tie-rod joint)
#8 Posted : Thursday, 8 September 2005 6:59:15 AM(UTC)
Munromad2004
Thanks for that info guys. I have just remembered I have a set of HQ ones in the shed but I don't know if they came from a manual or power steering car.
My GTS is manual steer so if they're shorter than those then they must be power steer ones. I'll
#9 Posted : Thursday, 8 September 2005 8:06:14 AM(UTC)
Yes, you were silly... :-))
The HQ steering arms are ALL the same...power steer and manual steer are both the same length in the HQ's.
In the HJ - WB's, the manual steer cars had longer steering arms. The Power steer cars stayed with the exact same
#10 Posted : Thursday, 8 September 2005 8:46:38 AM(UTC)
Munromad2004
Thanks for clearing that up. I must admit that I still wasn't sure about the differences even after reading the previous posts. It sometimes takes a while for things to sink in!!
I'm imagining that the HJ-WB manual steer cars used a longer steering a
#11 Posted : Thursday, 8 September 2005 4:33:04 PM(UTC)
Hi Guys.
To try & make this all a bit clearer. The steering arms on all power steered HQ-WB are the same (short) item.
To lighten up the steering effort, GM-H in late HJ, made the arms on the manual steer cars longer.
When converting to power ste
#12 Posted : Friday, 9 September 2005 5:20:38 AM(UTC)
Alternatively, Darren, if you want lighter steering for your HQ GTS without fitting power steering, fit the later arms...
Cheers...Dave
#13 Posted : Saturday, 10 September 2005 2:44:00 AM(UTC)
Munromad2004
Now that's a good idea. I think I'll stick the power steering on the GTS and use your idea on the SS as it is going to be restored as completely original as I can and they weren't available with power steering.
Thanks for that. Once again I know real
