#1 Posted : Wednesday, 7 September 2005 9:58:41 PM(UTC)
what oil do you peoples recommend for a hz 5litre v8
im currently using mobil xhp 20w50
trubluhq Offline
#2 Posted : Wednesday, 7 September 2005 11:29:45 PM(UTC)
trubluhq
Hi OD,
Go buy some Penrite ! Get rid of any BIG name oil. Its rubbish. Depending on the condition of your motor, pick any Penrite from 20 to 40 grade. Best oils I have used.
Rgds, John
trubluhq Offline
#3 Posted : Wednesday, 7 September 2005 11:29:45 PM(UTC)
trubluhq
Hi OD,
Go buy some Penrite ! Get rid of any BIG name oil. It's rubbish. Depending on the condition of your motor, pick any Penrite from 20 to 40 grade. Best oils I have used.
Rgds, John
#4 Posted : Thursday, 8 September 2005 12:19:32 AM(UTC)
thinking of changing to15w50 from 20w50 is this grade ok for this type of motor
peterwmh Offline
#5 Posted : Thursday, 8 September 2005 12:42:27 AM(UTC)
peterwmh
Yep I'm with John on this one, I run a Penrite 20W-50 in my HZ 308 and it works great, nil oil usage and so far no problems with the engine (probably shouldn't put that into words). If you're doing some heavy towing or long highway miles maybe HPR30 is a
Edited by user Thursday, 8 September 2005 12:43:30 AM(UTC)  | Reason: Not specified
peterwmh Offline
#6 Posted : Thursday, 8 September 2005 12:42:27 AM(UTC)
peterwmh
Yep Im with John on this one, I run a Penrite 20W-50 in my HZ 308 and it works great, nil oil usage and so far no problems with the engine (probably shouldnt put that into words). If youre doing some heavy towing or long highway miles maybe HPR30 is a be
Vintage Caravans Offline
#7 Posted : Thursday, 8 September 2005 1:03:04 AM(UTC)
Vintage Caravans
I will third that notion, all I use throughout all of my cars is Penrite! great oil!
We even used to run five Harleys out at Ayers Rock on it, air cooled bikes riding hard in forty degree heat, cant recommend it enough!
Matt
Looking for Old C
1962 EK Wagon - Chev SBC & T700, 1962 EK Sedan - Chev SBC & T700,EK Ute - V6 Buick & 5 speed = LOOKING FOR A 1962 EK VAN
#8 Posted : Thursday, 8 September 2005 4:52:58 AM(UTC)
Im with you guys - HPR30 for my 202 since day one! Penrite is the only oil i have and will ever use!!
Don't bag the UC, it might just be the car that kicks ur ass!!
#9 Posted : Thursday, 8 September 2005 4:52:58 AM(UTC)
Dont bag the UC, it might just be the car that kicks ur ass!!
#10 Posted : Thursday, 8 September 2005 5:16:44 AM(UTC)
is 15w50 an ok grade to use for a 308??
#11 Posted : Thursday, 8 September 2005 6:05:02 AM(UTC)
Here's how i work it...
If the motor (old holden motor - that is) is rebuilt within the last 80 000kms, 15w50 or anything up to 50, if its getting a little old and tired, 25w60 (hence what im using)!
The older motors tend to start using oil a bit mo
#12 Posted : Thursday, 8 September 2005 6:05:02 AM(UTC)
Heres how i work it...
The older motors tend to start using oil a bit mor
#13 Posted : Thursday, 8 September 2005 7:23:04 AM(UTC)
I use Shell helix ultra (full synthetic) in my LPG HZ 308. Uses a little bit (about 1L per 10,000kM). You can pick it up at Supercheap on special for about $45/5L.
#14 Posted : Thursday, 8 September 2005 7:42:36 PM(UTC)
I have always used Valvoline XLD plus. My Falcon has done 420,000 kays & still runs fine. My last Falcon did 291,000 before being written off & I pulled the head, the thing still had the hone marks in the bores. My VP Commodore has done 200,000+ & still r
ozjason Offline
#15 Posted : Thursday, 8 September 2005 8:57:32 PM(UTC)
ozjason
Im with Jim. Valvoline. Did many years on the old engine using it, and I fully expect to get many more on the new engine using Valvoline again.
Jason.
ozjason Offline
#16 Posted : Thursday, 8 September 2005 8:57:32 PM(UTC)
ozjason
I'm with Jim. Valvoline. Did many years on the old engine using it, and I fully expect to get many more on the new engine using Valvoline again.
Jason.
#17 Posted : Thursday, 6 October 2005 10:52:59 AM(UTC)
At work we have used Castrol in all of our industrial engines for the past 15 years. These engines run 24 / 7 and have racked up 100,000 hours. Thats around the world many times. We pull the engines down every 30,000 hours and they look brand new. Im conv
#18 Posted : Thursday, 6 October 2005 10:52:59 AM(UTC)
At work we have used Castrol in all of our industrial engines for the past 15 years. These engines run 24 / 7 and have racked up 100,000 hours. Thats around the world many times. We pull the engines down every 30,000 hours and they look brand new. I'm con
#19 Posted : Saturday, 10 November 2007 1:55:46 AM(UTC)
on valvoline just ask john laws all the best
basketcasebear Offline
#20 Posted : Saturday, 10 November 2007 4:57:28 AM(UTC)
basketcasebear
I used to have a diesal, and it literally used more oil than fuel, untill i put in fuch,s,, fusch,s??hhmm?? anyway that one?
it never used a drop after that, and even ran betterer after?
ptpro
DOH!!!
