Fastlane
Holden Forums
Holden General Discussion
DO YOU NEED A DEMISTER WORKING FOR REGO ?
DO YOU NEED A DEMISTER WORKING FOR REGO ? BARGAIN BRAND NEW UNDER DASH HEATER AND AIR CONDITIONING WITH DEMISTER DUCTS AND EYEBALL DUCTS TO SUIT HOT ROD, 4WD OR OTHER AUTOMOTIVE application THE UNIT IS NEW ,THE CASING IS PLASTIC AND HAS BOTH HEATER EVAPORATOR CORES INSIDE UNIT HEATER CORE IS ALUMINUM WITH 16 MM OUTLETS OVERALL dimension are as below HEATER AIR CONDITION Specs CUBIC FEET METRE 359 Dimensions 400 MM X 325 MM X 125MM COOL K/CAL 2650 HEAT K/CAL 4800 Volts 12 2242EV The unit has a twin blower wheels with a three speed 12v motor THIS UNIT IS COMPLETE WITH 2X DEMISTER DUCTS , 2X EYEBALL AND ONE UNDER DASH HEAT/COOL EVAPORATOR $350.00 INC GST NOTICE: TRADE & WHOLESALER WELCOME Email for price www.geocities.com/radiatorexpert/ OR EMAIL [email protected] PLEASE NOTE : YOU WILL NEED A/C COMPRESSOR , CONDENSER ,R/DRIER AND A/C HOSES
Unlike modern cars with NO flow thru ventilation eg VR-VX commodes, the old HQ can get by without even a fan ! That's why modern cars need aircon.
John
Hi trubluhq.
The HQ holden was the 1st Holden WITH flow-thru ventilation. It had face-level dash vents & outlet vents in the rear door openings. They also had no glass quarter vents on the front doors.
Dr Terry. |
The factory manuals for the HQ have very detailed drawings of the direction of airflow throughout the cabin and boot area.
I never knew how much thought and planning actually went in to designing the air circulation system on a car. Quite an eye opene
I had visions of modifying mine to fit HG or something quarterwindows. Flow through just does not work properly in the heat of australia.
Ummm, how would a mechanic test the demister to see if it was working anyway?
I am doubting they are going to stick a voltmeter across it....
___________________ Why are you reading this, you should be looking up there^^ |
___________________ - HJ turbotonner looks and goes like a sneezing rhino on heat! - |
They just see if its blowing hot air onto the windscreen, in the mini's with out heaters they just used a 12 volt hairdryer up under the dash:) These units are cheaper than the vintage air units, guess see if blokes run them and if they cool a large 4 doo
my hk kingswood has no fan whatsoever...no radio either :| has disc brakes though
in reply to the original post, only if your car had it in the first place ;)
i think i'll have another look at that website though, i still want a heater!
[IMG]http
Fastlane
Holden Forums
