ozjason Offline
#1 Posted : Wednesday, 5 October 2005 11:04:29 PM(UTC)
ozjason
Here's one of those things that hide out of sight in your car, slowly deteriorating over time, that might bite some of us eventually...
Smelt a funny fuel smell in the Torana the other day... almost disregarded it, as you can always smell fuel or oil in these old girls. However, I took a closer look.
Turned out to be the 6-inch piece of 8mm rubber hose that goes from the fuel filler to the tank as a breather hose. The rubber had perished and there was fuel dribbling out. Only picked up because it was a full tank of fuel.
Got under the tank to check the other ones (there are 6 more small sections joining up the various fuel lines in front of the tank. These had deteriorated BADLY, and were also dribbling fuel... and three of these sit above the exhaust pipe!
So, if you're running a fairly stock or original old car that's around this age, do yourself a favour and check those rubber joiners around your fuel tank fittings! Seven pieces in total on the Torana, plus two in the engine bay around the fuel filter. Several different sizes, we got away with a length of 6.5mm line, and some 10mm line. Some 8mm would have been handy, too. Oh - and some new hose clamps to replace the rusty clips.
Very easy job that might save yourself and your car if yours are perishing too.
Jason.
Edited by user Wednesday, 5 October 2005 11:06:26 PM(UTC)  | Reason: Not specified
trubluhq Offline
#2 Posted : Thursday, 6 October 2005 2:15:53 AM(UTC)
trubluhq
Hi Jason,
A very good tip. Will check mine ! I wonder if ethanol will only add to this problem ?
Must buy some Manildra Sugar shares !!!!!!
Rgds John
Munromad2004 Offline
#3 Posted : Thursday, 6 October 2005 6:31:44 AM(UTC)
Munromad2004
How many of us drive older cars yet fail to check these simple things which could cost us our pride and joy (or much worse).
I have to get under my GTS to change the rear shockers this weekend so I'll make the effort to check out my fuel lines as well.
#4 Posted : Friday, 7 October 2005 4:44:04 AM(UTC)
the exact same thing happens in EFI commodores.
but because they recycle the fuel back through those lines, it squirts out everywhere.
i went through a tank of fuel in 30 km's.
VN Calais, V8 Auto, Blown etc etc.
Air con, Electrical, Car audio Mast
ozjason Offline
#5 Posted : Friday, 7 October 2005 5:00:24 AM(UTC)
ozjason
Well, the fun and games never ends... had to get to a band job tonight. The car started fine on the weekend after we'd changed the rubber bits of the fuel line, so I assumed it'd all be fine tonight.
Got about half a kilometre from home... she konks
Edited by user Friday, 7 October 2005 5:02:01 AM(UTC)  | Reason: Not specified
bluHJ Offline
#6 Posted : Friday, 7 October 2005 5:24:11 AM(UTC)
bluHJ
Nothing quite like being kinky is there Jason?
bluHJ
#7 Posted : Friday, 7 October 2005 5:33:27 AM(UTC)
Jason,
Did you eventually get my E-mail?
If not, call me on 0417 994 668 and I'll call you back.
Cheers...Dave
