#1 Posted : Tuesday, 11 October 2005 4:28:14 PM(UTC)
Can someone give me some directions on opening it up?
If you have made up some sort of release tool in the past some measurements or description would be awsome.
Nick
ozjason Offline
#2 Posted : Tuesday, 11 October 2005 7:06:35 PM(UTC)
ozjason
Angle Grinder.
Just kidding... :-) Where did it snap? Right at the bonnet end, or somewhere in the middle? If it's not at the bonnet end, you may be able to thread the cable down under the car and use a pair of pliers to pull it?
If it busted at
#3 Posted : Wednesday, 12 October 2005 6:06:11 AM(UTC)
At the bonnet end aye...don't know anyone with similar car...anyone else have any experience with this...dont want to chop it
nick
jabba Offline
#4 Posted : Wednesday, 12 October 2005 3:17:36 PM(UTC)
jabba
If it is similar to the HQ, there is a metal flange which the cable passes through and then cable clamps on the other sideto operate. To prevent heathen thieves getting to it, there is a plate in front of and over the mechanism, to stop it being operated
#5 Posted : Wednesday, 12 October 2005 5:51:13 PM(UTC)
or try the steel wire from a coat hanger.
make sure you lube the mechanisms and cable well when you replace it!
www.68hk.oldholden.com
there are no stupid questions, only stupid pe
#6 Posted : Thursday, 13 October 2005 2:58:15 AM(UTC)
hi
i used a old haksaw blade covered in elec tape to open my HR bonnet
put it in frount of the tab where the cable fits on and leaver it open aginst the locking bolt with the big spring on it hope you can understand what i mean
MARK
