6pak Offline
#1 Posted : Saturday, 23 December 2006 9:36:49 AM(UTC)
6pak
Hi all. I'm re-assembling the rear brakes on the ZD and have hit a snag. One of the metal brake lines has a small section at the start of the hydraulic connection that is cross threaded (i don't think it was me i only removed it!). What size die do i need to tidy the thread up?
#2 Posted : Tuesday, 2 January 2007 10:18:07 PM(UTC)
It is an odd thread size. I think they are what they call BSP which is british standard pipe. Just tidy it up a touch with a file if you like or it does not cost much to get a brake line made
XB351 Offline
#3 Posted : Wednesday, 3 January 2007 1:33:55 AM(UTC)
XB351
You can also just replace the line. Any line from a borg warner diff either disc or drum will do. BW lines also work on the 9" diff. Had to use on on a mates 9". Raided his prior bw for the lines for a 9" conversion.
6pak Offline
#4 Posted : Wednesday, 3 January 2007 11:12:20 AM(UTC)
6pak
thanks guys. I was able to tidy it up with a fine file. In the end the problem was that the new wheel cylinders had been manufactured with a different thread to what was used in the original lines. a couple of old trailer parts i had actually screwed i
This page was generated in 0.116 seconds.
