RussVRute Offline
#1 Posted : Thursday, 20 October 2005 7:10:04 AM(UTC)
RussVRute
G'day All,
I was just wondering how different the couplings are between power and manual steering on the tonner, and if they can be made to fit the other? and if so will it affect the steering ? cheers. Russ.
trubluhq Offline
#2 Posted : Thursday, 20 October 2005 7:19:28 AM(UTC)
trubluhq
I swapped mine around and fitted no probs...seemed the same. Only difference is the rods from the coupling to the steering box as I see it.
John
classic oz wreck Offline
#3 Posted : Friday, 21 October 2005 5:24:33 AM(UTC)
classic oz wreck
if you are talking the rubber/nolathane piece only...yes they are the same...
www.classicozwreck.com.au
#4 Posted : Saturday, 22 October 2005 7:53:15 AM(UTC)
You sure about that? I was pretty sure the coupling and the shaft to the steering box were different.
#5 Posted : Saturday, 22 October 2005 10:02:57 AM(UTC)
Yes, they are different.
The manual steer shaft is all spline and the power steer shaft has a flat section on it as well as spline. They won't interchange. I know, as I have converted my HZ to power steering and had to buy a new coupling.
#6 Posted : Saturday, 22 October 2005 4:43:20 PM(UTC)
Hi Guys.
You are both correct.
Yes the couplings are different, the boxes have different splines on the input shaft.
But as Classic Oz Wreck said, he was only talking about the 'rubber/fabric' bit itself.
Nolathane (& others) make a replacem
#7 Posted : Sunday, 23 October 2005 9:25:14 AM(UTC)
I just had this vision in my mind that the shaft on the power steering model was thicker and the flange bigger therefore needing a bigger rubber/fabric thing.
But it must have been just a figment of my imagination, much like my imaginery bank balnce bein
