#1 Posted : Tuesday, 25 October 2005 7:40:18 PM(UTC)
Hi, can anyone give me some guidance how I can identify if a Trimatic is the efi VK transmission please - I have very little familiarity with these boxes. Thanks, Tom
Mr Void Offline
#2 Posted : Tuesday, 25 October 2005 7:54:09 PM(UTC)
Mr Void
I'm sure someone said a little while ago that they are painted black.. not that you can't paint any other tri black.?
I don't know any other markings to look for but don't worry some one else will be along soon to fill you in!
___________________
___________________
#3 Posted : Tuesday, 25 October 2005 8:23:34 PM(UTC)
Thanks Mr Void, I am going to be looking at a VK that has been messed around with, and I want to make sure it is the correct box. It would also help to know the range of engine numbers to make sure it is a black block, as this stuff could have been painte
#4 Posted : Tuesday, 25 October 2005 10:37:07 PM(UTC)
Almost all black blocks are different from blue blocks where the engine number is stamped. Blue blocks have a smooth machined surface like a red motor. Black blocks are rough cast where the number is stamped. An EFI engine is even easier to identify, as t
#5 Posted : Tuesday, 25 October 2005 10:45:22 PM(UTC)
Thanks Byron, that is very helpful indeed. Are you able to shed any light on differentiating an EFI box from a standard 6cyl Trimatic? Thanks, Tom
#6 Posted : Wednesday, 26 October 2005 3:41:58 AM(UTC)
The EFI gearbox should be coded LR. The EST one should be LP. There is also another hint:
EST engine trimatics had a hole in the bellhousing just behind the head for the crank position sensor to poke through.
#7 Posted : Wednesday, 26 October 2005 8:19:44 AM(UTC)
And the EFI trimatics ran a filthy big reinforced bellhousing.
#8 Posted : Wednesday, 26 October 2005 8:25:35 AM(UTC)
Surely they would have been clean when they came from the factory Mick? :-))
Cheers...Dave
Sorry, couldn't resist...
Edited by user Wednesday, 26 October 2005 8:26:17 AM(UTC)  | Reason: Not specified
#9 Posted : Wednesday, 26 October 2005 9:30:10 AM(UTC)
Thanks guys, helpful advice as usual and much appreciated. Tom
#10 Posted : Wednesday, 26 October 2005 6:18:05 PM(UTC)
__
#11 Posted : Thursday, 27 October 2005 4:33:59 AM(UTC)
I ripped one out of a VK EFi to put in a mate's HJ ute, and it wouldn't fit.
There were other issues, but one of the main differences was the wider cast edge around the perimeter of the bellhousing. It also had extra webbing on it.
This extra mater
#12 Posted : Thursday, 27 October 2005 6:21:16 PM(UTC)
OK. I never used one in a column shift situation, but I have used them behind red motors in HQ-WB. How did you get a left shift VK box to work with a right shift column shift mech??? Seems odd that Holden would do this simply for the EFI engine, as there
Mr Void Offline
#13 Posted : Friday, 28 October 2005 2:01:29 AM(UTC)
Mr Void
were the efi box internals any stronger than the older carby boxes??
___________________
Why are you reading this, you should be looking up there^^
___________________
#14 Posted : Friday, 28 October 2005 11:20:56 AM(UTC)
I am working on the assumption the efi box is actually a V8 box... someone please correct me if I'm wrong because I will get any commodore box if thats the case for my 6cyl hg monaro.
#15 Posted : Friday, 28 October 2005 5:48:59 PM(UTC)
The EFI box had beefed up internals similar in spec to the V8 trimatic.
This page was generated in 0.092 seconds.
