#1 Posted : Wednesday, 26 October 2005 1:01:44 AM(UTC)
G'day all. Well I'm just trying to sort out some info regarding starter motor's for the V6. Due to the conversion into EH the original series 1 VN auto starter is to big to fit. Have been told to use a series 2 or VP Auto starter? I have a spare VP starter and have fitted it in with no problems but just checking if there is any reason why I can't run the newer Delco Remy rather than the Bosch?? The workshop manual I have has "not interchangeable" written with regards to swapping them?? Any problems with pinion/gear's or is ok to use? The Bosch has 9 teeth and the Delco has 10 but the pitch of the teeth looks the same. I have to pull the motor back out to modify the conversion sump so I have not started the motor yet.
Cheer's
life's to short not to be....
#2 Posted : Wednesday, 26 October 2005 8:03:57 PM(UTC)
Well I have just tried to go the other way Please read my posts http://www.fastlane.com....topic.asp?TOPIC_ID=4685
and also
http://www.fastlane.com....topic.asp?TOPIC_ID=4344
I also have a VN engine and auto & what I have found o
#3 Posted : Wednesday, 26 October 2005 8:45:35 PM(UTC)
Thanks Jim, left you a note on your last post about this one. I have a 2nd hand Delco from a VP already to replace the series 1 VN Bosch. But was just checking with regards to the actual throw out, meshing and the extra tooth. Been told they work OK but j
#4 Posted : Wednesday, 26 October 2005 9:10:39 PM(UTC)
I went through AutoPro & got a very good price as my brother sold it to me (retail was around $170). What I am going to do is go down to my local holden dealer & find out if the VP flex plate is the same part number as a VR flex plate. If it's the same I'
#5 Posted : Wednesday, 26 October 2005 9:25:08 PM(UTC)
Got a VP and another series 1 Vn flex plate in the shed. Will count them up and see. The teeth are the same pitch on the starter's so it should be OK?
#6 Posted : Thursday, 27 October 2005 7:53:29 PM(UTC)
That would be great. What concerns me more than the pitch of the teeth is that the 9 tooth pinion is smaller than the 10 tooth pinion so therefore in theory should require a slightly larger diamter flywheel/flexplate OR the pinion is in a slightly differe
#7 Posted : Monday, 31 October 2005 1:42:44 PM(UTC)
Well Jim....I measured up the starter's from centre of front mounting bolt to the tip of the tooth on the cog (across the front). There the bloody same!!?? just have a look at the mounting hole and outside edge of the cog teeth and you'll see what I mean.
Edited by user Wednesday, 2 November 2005 3:04:40 AM(UTC)  | Reason: Not specified
This page was generated in 0.065 seconds.
