#1 Posted : Tuesday, 1 November 2005 2:42:39 AM(UTC)
hi there
I have come to the point where i need to rebuit my gearbox. Its the 4 speed tourquemaster that only done about 75000kms. As its a bit expensive to do this standard job i was thinking of other gearboxes that i could put in instead. Does anyone rate the 5 speed borg warner boxes? Should i stick with what ive got? Are there any other gearboxes that will fit?
rohan
#2 Posted : Tuesday, 1 November 2005 5:58:48 AM(UTC)
Aussie 4-speed M20 or M22; Supra or Celica (talk to Dellow); 5-speed Borg Warner; Trimatic. Many options. An original Holden conversion would be your best bet.
#3 Posted : Wednesday, 2 November 2005 8:37:18 PM(UTC)
go supra for best value.
your 6 should never break it either.
a couple of grand for full conversion.
you may be able to save some if yours is manual already
VN Calais, V8 Auto, Blown etc etc.
Air con, Electrical, Ca
#4 Posted : Thursday, 3 November 2005 4:12:01 AM(UTC)
thanks for that
are there any differences between the supra and celica box?
would it be cheaper just to buy another gearbox then rebuilding the one i have?
can you put different gear ratios in or would this be on the expensive side?
and borg warner
#5 Posted : Thursday, 3 November 2005 5:13:47 PM(UTC)
borgwarner is fine, but not as good as a supra turbo box.
changing ratio's is a fairly big job.
the stock supra ratio's are good, just change your diff ratio to get the revs/speed you want.
#6 Posted : Thursday, 3 November 2005 9:17:38 PM(UTC)
can the supra box be from any era or does it have to be 80's style?
#7 Posted : Thursday, 3 November 2005 9:31:16 PM(UTC)
i having trouble finding any 5 speed gearbox in brisbane that will fit. Any suggestions where i should be looking? I have called most general wreckers around here.
#8 Posted : Friday, 4 November 2005 10:28:01 AM(UTC)
Call a Mal Wood Autos in Qld or CRS in Vic or Dellow in Sydney. Dellow will make a bellhousing to adapt the box to your motor. They (or the other guys) should have a box to suit or be able to advise you where to get one.
Cheers...Dave
#9 Posted : Monday, 7 November 2005 5:22:04 AM(UTC)
Would a W57 supra box be ok for fitting??
Dylan Offline
#10 Posted : Monday, 7 November 2005 6:29:04 AM(UTC)
Dylan
yes, W57 and W55 are the 2 most common used in conversions
This page was generated in 0.065 seconds.
