ozchevy Offline
#1 Posted : Monday, 14 November 2005 7:58:50 AM(UTC)
ozchevy
I have a Saginaw power steering pump on my Camaro, it is very light in it's turning control and really dont feel the road too well through the steering wheel. I literally have to turn the steering wheel back from making any sort of turn. I have what looks like the same pump in my HQ Statesman - however the feel of the Statesman's steering ****s all over that of the Camaro, which I find odd, as the steering conversion left to right in the Camaro is all HQ components.
Any thoughts out there on why this might be.
#2 Posted : Monday, 14 November 2005 8:24:40 AM(UTC)
Measure your steering arms (between tie-rod ends and hubs). They should be about 91 mm from the middle of the front bolt-hole to the middle of the tie-rod end's nut. If they are 122mm (or thereabouts) they are for manual steering and should be replaced wi
#3 Posted : Friday, 18 November 2005 8:56:27 AM(UTC)
Hi ya I have a 69 valiant, it suffers the same problems as what you are describing, In the valiants case the problem lieS within the steering box ratio and valving, probably the same in the camaro. Just read more of your story, same steering box as the hq
ozchevy Offline
#4 Posted : Saturday, 19 November 2005 6:21:08 AM(UTC)
ozchevy
Had another good look at the steering in the Camaro, checked the measurements of tie rod ends to the hubs, found nothing there. What I have discovered is the steering shaft coupling is not an HQ coupling, it's actually a steel universal joint - probably m
#5 Posted : Saturday, 19 November 2005 11:12:42 AM(UTC)
Check the CASTOR as well as camber. Neg castor will give lighter steering, while positive will make the steering heavier.
classic oz wreck Offline
#6 Posted : Monday, 21 November 2005 10:23:53 AM(UTC)
classic oz wreck
ozchevy...what model camaro do you have?...there was many different conversions done to these and some are good and some were bad!...for more specific and good information regarding your car and its conversion go to www.camaro-firebird.org
this is a spec
Edited by user Monday, 21 November 2005 10:29:14 AM(UTC)  | Reason: Not specified
www.classicozwreck.com.au
#7 Posted : Monday, 21 November 2005 10:26:52 AM(UTC)
classic oz wreck
BTW...when you follow the link at the top of the page go to forums...cheers greg
ozchevy Offline
#8 Posted : Tuesday, 22 November 2005 8:19:16 AM(UTC)
ozchevy
Hi Greg,
I have a second gen Camaro 79 Z/28. The conversion was done in Melbourne and they did a great job on it, it a mirror conversion. I'm sure the reason the uni joint steering shaft connector was used - was because the header pipes were so close to
This page was generated in 0.083 seconds.
