#1 Posted : Monday, 14 November 2005 9:37:53 PM(UTC)
Okay guys I know you're all more partial to the bigger cars, but I have a question hopefully someone can answer.
I have a (very) early TD Gemini station wagon (one of the first 15) and need to check to see if the numbers match.
I know how to read the compliance plate/body and option plate etc (have the parts manuals etc) but is there any way of confirming whether the body and option plate matches the compliance plate?
The numbers appear to be correct; colour, gearbox type, trim etc however the compliance plate shows it is made in Adelaide (ATD000**A) whereas the body number indicates a Brisbane production car. I've read a few threads here and there about errors in the compliance/option plates and hoping this is the case and not that there has been a swap.
Thanks in advance!
blwnhj Offline
#2 Posted : Tuesday, 15 November 2005 2:18:59 AM(UTC)
blwnhj
i used to have a td wagon. Great little car. gave me hrs of amusement in the wet!!!!
in regard to your question, i had a similar deal.
when i first got it registered a vic roads burwood i parked under the bay and a little man come out to check the num
BLWNHJ
#3 Posted : Wednesday, 16 November 2005 7:46:13 PM(UTC)
I was unbder the impression that ALL Geminis were made in Brisbane. As it is so early it might have been a prototype so initially built in Brisbane then sent to adelade for completion or visa versa. This is a bit more common is some other models, built in
peter_flane Offline
#4 Posted : Wednesday, 16 November 2005 9:16:43 PM(UTC)
peter_flane
That is always a sad thing when certain numbers get cut off in an accident. I know a mate who had an EH which had been restored 20 years ago with a new NOS subframe, which had no chassis number of course. The vehicle was then registered using the number o
#5 Posted : Thursday, 17 November 2005 10:05:04 AM(UTC)
I'm personally leaning toward the built in Brisbane and finished in Adelaide' theory. It's very early (in the first 20 in fact) and hence it may have actually been the first wagon (here's hoping).
Does anyone know how to find out from Holden or somewh
blwnhj Offline
#6 Posted : Thursday, 17 November 2005 7:04:41 PM(UTC)
blwnhj
good luck trying to source that info from 20-30 odd yrs ago, holden prolly laugh at the thought of trying to look up that info.
im having trouble getting a wiring diagram out of a vx from them.
BLWNHJ
BLWNHJ
#7 Posted : Friday, 18 November 2005 3:03:16 AM(UTC)
Simple solution......join the Gemini car club.
#8 Posted : Friday, 18 November 2005 3:17:34 AM(UTC)
The Gemini Car Club?
I don't think they are interested or able to provide this sort of info. If you're a member - let me know.
