2 Pages<12
ozjason Offline
#21 Posted : Sunday, 27 November 2005 7:22:42 AM(UTC)
ozjason
Dylan,
I've got the same problem... the standard hole is a bit too high but not wide enough for a standard single DIN. Shame... I was going to try to avoid cutting it wider, but then - any configuration this HQ ever has will have a stereo in there, a
#22 Posted : Sunday, 27 November 2005 7:43:54 AM(UTC)
Hi Jason,
STILL looking for a box big and strong enough to send that aircon stuff to you.
How did you go with the alarm? You may be able to find some help here: http://www.the12volt.com/
Cheers...Dave
bluHJ Offline
#23 Posted : Sunday, 27 November 2005 7:58:53 AM(UTC)
bluHJ
Try getting a set of door pockets and speakers from a VT. They are supposed to fit and all you do is screw them to your door trims from inside. The VX, VY, VZ ones should fit.
bluHJ
ozjason Offline
#24 Posted : Monday, 28 November 2005 6:35:39 AM(UTC)
ozjason
Dave,
Not a bad site, I'll keep it in mind for later, but it didn't help in this case. But... finally had some success!
Turned out I had a dodgy module. I switched in the module from the second alarm that was going to go into the ute, and it was a
#25 Posted : Monday, 28 November 2005 9:06:21 AM(UTC)
Good, mate, at least the problem is solved.
Let's hope Mongoose come to the party with a replacement Module.
Cheers...Dave
Guest (10)
2 Pages<12
