#1 Posted : Tuesday, 15 November 2005 7:22:48 AM(UTC)
gday all. when i first put the 253 in my ute it had a 350 holley which was a bitch to start. so i upgraded to a 4 barrel Carter quadrajet of a VK that i picked up for $50 (the carby that is)
anyway ive had a few blokes tellin me i would be better off gettin a rochester quady as the original holden manifolds with the carter quad make it run thirstier as opposed to the rochy's
any suggestions?
#2 Posted : Tuesday, 15 November 2005 7:23:57 AM(UTC)
forgot to add that they are sayin something about less airflow on the older manifolds cheers
#3 Posted : Tuesday, 15 November 2005 8:28:59 AM(UTC)
I was running a rotty on my 253 with factory manifold and it ran well , I have just changed back to a 2bbl stromberg (rebuilt) and it runs just as well with a better fuel economy. If you are running LPG as well go the 2 bbl stromberg as they run well with
