#1 Posted : Friday, 18 November 2005 9:08:21 AM(UTC)
Hi all got a trimatic, that shifts up gears beautiful, but on automatic change down of gears, it really Thumps Oil level is fine, Someone ripped me a yarn about one of the servo valves in the valving body fails and becomes seperated? Anyone know of this problem and how to fix it????
666 Offline
#2 Posted : Tuesday, 22 November 2005 7:02:43 AM(UTC)
666
Where did u get it from ?
Some Shift kit attempts can b dodgy.
Also note some diff noises only occur in decell.
666
666
Mr Void Offline
#3 Posted : Tuesday, 22 November 2005 7:04:48 AM(UTC)
Mr Void
not sure on the servo valves but could the problem lie with the detent switch behind the accel pedal??
What vehicle is it in??
___________________
Why are you reading this, you should be looking up there^^
___________________
#4 Posted : Tuesday, 22 November 2005 8:02:08 AM(UTC)
Hi Guys.
This is a fairly common problem in series 2 & 3 Tri-Matics. The valve you mention is often called the dump valve & it's a small peice if plastic that restricts oil flow & one direction & allows quick flow in the other (slow apply, quick releas
#5 Posted : Wednesday, 23 November 2005 2:25:32 AM(UTC)
Seems like you have a bit more of a problem there. Long term i would replace it. If you are keen on the car, spend some money on it!
iitsmint Offline
#6 Posted : Monday, 28 November 2005 9:55:04 PM(UTC)
iitsmint
Hi, Dr Terry has got it it in one, I have a spare box stripped down, I am unable to identify the dump valve mentioned, can anyone locate it in the holden hq transmission manual, or otherwise describe where it lives. ta
#7 Posted : Tuesday, 29 November 2005 3:52:52 AM(UTC)
Hi Guys.
The HQ Tri-Matic does not have the little dump valve, It's in series 2 & 3 which is in HX onwards.
Honestly, it's not an expensive job, let the pros do it, & have it looked at & serviced at the same time. Get some quotes.
#8 Posted : Monday, 26 December 2005 10:15:31 PM(UTC)
For those wondering, I eventually nutted out the location of the "dump Valve" Located between the valve body spacer plate and the transmission casting. It locates in a hole in the said plate on one end and fits in the bottom of the transmission casting, C
