Hi all got a trimatic, that shifts up gears beautiful, but on automatic change down of gears, it really Thumps Oil level is fine, Someone ripped me a yarn about one of the servo valves in the valving body fails and becomes seperated? Anyone know of this problem and how to fix it????
Where did u get it from ?
Some Shift kit attempts can b dodgy.
Also note some diff noises only occur in decell.
666
666 |
not sure on the servo valves but could the problem lie with the detent switch behind the accel pedal?? What vehicle is it in??
___________________ Why are you reading this, you should be looking up there^^ |
___________________ - HJ turbotonner looks and goes like a sneezing rhino on heat! - |
Hi Guys.
This is a fairly common problem in series 2 & 3 Tri-Matics. The valve you mention is often called the dump valve & it's a small peice if plastic that restricts oil flow & one direction & allows quick flow in the other (slow apply, quick releas |
Seems like you have a bit more of a problem there. Long term i would replace it. If you are keen on the car, spend some money on it!
Joined: 12/10/2005(UTC) Posts: 147 ![Australia Australia]() Location: WA
Hi, Dr Terry has got it it in one, I have a spare box stripped down, I am unable to identify the dump valve mentioned, can anyone locate it in the holden hq transmission manual, or otherwise describe where it lives. ta
Hi Guys.
The HQ Tri-Matic does not have the little dump valve, It's in series 2 & 3 which is in HX onwards.
Honestly, it's not an expensive job, let the pros do it, & have it looked at & serviced at the same time. Get some quotes.
Dr Terry |
For those wondering, I eventually nutted out the location of the "dump Valve" Located between the valve body spacer plate and the transmission casting. It locates in a hole in the said plate on one end and fits in the bottom of the transmission casting, C
