ChrisHQUTE Offline
#1 Posted : Wednesday, 30 November 2005 12:38:43 AM(UTC)
ChrisHQUTE
G'day fella's is there someone out there that can tell me how to tune up a black fuel injected six, as the ute is running like ****.
The timing seems to be right but it is still running to rich and I do not have a clue what to play around with on the fuel injection to get the thing to run right. Even when driving it feels like it has left its nuts back in the garage, it just doesn't like to rev anymore.
any help would be appreiciated thanks
If a man say's something in the woods and there is no women around, is he still wrong?
blwnhj Offline
#2 Posted : Wednesday, 30 November 2005 2:19:27 AM(UTC)
blwnhj
in my opinion its prolly one for the pro's with all the right epuipment. if your in melb i can reccomend a guy that in the outer south east suburbs that is mainly a dizzy guy but will do dizzy and tune it up great. he recently did my efi blk motor and it
BLWNHJ
#3 Posted : Wednesday, 30 November 2005 6:46:11 AM(UTC)
A couple of things that i did to my motor to get it to run 'right'...
Rotor button
Distributor cap
Spark plugs and leads
Timing
Fuel system cleaner
My car felt more lively after these small things... Not saying that they need to be done, but mi
Edited by user Wednesday, 30 November 2005 6:48:07 AM(UTC)  | Reason: Not specified
jabba Offline
#4 Posted : Wednesday, 30 November 2005 5:26:18 PM(UTC)
jabba
If a fuel injected vehicle is running too rich, it could be the o2 sensors in the exhaust also. The fuel control system senses the richness of the mixture by the amount of oxygen in the exhaust gases, and adjusts the mixture to suit (depending on how cle
#5 Posted : Thursday, 1 December 2005 7:07:21 AM(UTC)
Agreed also with the above!
Love the use of technical terms, and computer check terms too!
Death and life are just as pleasant as one another... Its the transition that is painful!
#6 Posted : Thursday, 1 December 2005 6:25:09 PM(UTC)
Hi Guys.
The VK EFI is only a Bosch LE-Jetronic system, very simple. The only sensing is coolant tent, air flow (& temp) & RPM. The is no O2 sensor & the TPS is only an idle & full throttle contact.
Common problems in these cars are high fuel pressu
peter_flane Offline
#7 Posted : Thursday, 1 December 2005 11:48:34 PM(UTC)
peter_flane
With our fuel injected 6 we had a faulty fuel pressure regulator and a faulty head temp sensor.
Two weeks later the computer gave up, we took it out, banged it on the ground and it worked for a while, but we had to replace it.
This page was generated in 0.097 seconds.
