jimbobhtute Offline
#1 Posted : Thursday, 15 December 2005 5:59:12 AM(UTC)
jimbobhtute
G'day guys,
I'm thinking of changing the 161 head off my Red 186 block for one I have in the garage so I can save a little money on fuel. However, I do not recognise the number stamped. It is:- 2811930 HOLDEN D 151 - L. (single post rockers, Hyd lifters)
Now I don't think it's a 186 head or 179, I need to know if this Head will cause any problems on the 186 block, like the 161 did. I am trying to make an engine that has a little grunt without reving it's tits off, hard to tune properly or not user friendly. Something reliable but fun.
As much detail about this style of head would be greatly apprieciated and if there a assiociated risks or problems that go with fitting it to 186 and extras ie: valves,cam, pushrods, carby settings (WW), pumps. Also the 161 has YT valves, would these be an advantage on the other Head depending on ID for performance?
On a seperate issue, I also have a Manifold with number: 7432238-88-2 stamped on it. Anybody got an Id for this?
Thanks for the help James
1970 HT UTE
Edited by user Friday, 20 January 2006 11:41:43 PM(UTC)  | Reason: Not specified
1970 Green HT UTE...
666 Offline
#2 Posted : Thursday, 15 December 2005 6:11:33 AM(UTC)
666
Strange,
I thought that a 161 Head (that is already a runner) would give you Better Fuel Economy (with its Higher Compression), than would a 186 Head ?
666
666
jimbobhtute Offline
#3 Posted : Thursday, 15 December 2005 6:31:13 AM(UTC)
jimbobhtute
666, I have been told that the Compression is to high for the fuel these days (11:1), even 98 octane not high enough or good grade to handle it. Does use the juice though.
1970 HT UTE
666 Offline
#4 Posted : Thursday, 15 December 2005 6:53:07 AM(UTC)
666
IF YOUR MOTA AINT PINGING, THE COMPRESSION IS SINGING !
I don't know wheather or not you, know "What Pinging Sounds like", some mechanics don't, im sure,
(it,s like somebody's tapping FAST at yr engine Block with a VB Bottle Top as you Drive).
The m
666
jimbobhtute Offline
#5 Posted : Thursday, 15 December 2005 7:42:46 AM(UTC)
jimbobhtute
Na thats fine 666, I can't say I have heard pinging as yet, but I realy do want to reduce the fuel consumption, performance and comfort (within reason). I might have a big cam fitted I don't know yet, will find out when I take it out in 2 weeks. The He
#6 Posted : Thursday, 15 December 2005 7:52:32 AM(UTC)
i might be interested in your 161 head if you want to sell it, i'm in qld.
jimbobhtute Offline
#7 Posted : Thursday, 15 December 2005 7:57:33 AM(UTC)
jimbobhtute
will keep ya in mind. Need to find more info on other head first. I'm in vic.
1970 HT UTE
80737k Offline
#8 Posted : Thursday, 15 December 2005 8:45:12 AM(UTC)
80737k
i got fond memories of an eh of a mates, it was a stock 179 running a stock 149 head. Once you convinced it to start it went hard and gained an extra 5 to 10 miles in top speed. It was fun.
Fossil fuels are YUMMY !
jimbobhtute Offline
#9 Posted : Thursday, 15 December 2005 9:01:48 PM(UTC)
jimbobhtute
Still looking for Id on the mystery Head guys....
1970 HT UTE
#10 Posted : Thursday, 15 December 2005 10:39:49 PM(UTC)
Hi jimbobhtute.
The 2811930 casting is an HQ/HJ/LJ 202 head. It's basically the same as a 179/186 head except that it has fixed rocker gear from the factory.
Dr Terry.
ozjason Offline
#11 Posted : Thursday, 15 December 2005 11:32:16 PM(UTC)
ozjason
I know this isn't what you asked about at all, but another description of the pinging noise that I've heard is someone rattling a glass jar of nails in your engine bay. Works for me - easy to pick and avoid once you've heard it a few times.
jimbobhtute Offline
#12 Posted : Friday, 16 December 2005 1:47:41 AM(UTC)
jimbobhtute
Thanks guys, So Dr Terry, Is this 202 Head a better option to choose over the 161 in regards to economy / power??? Depending on what I find out about the cam, I am thinking of putting just the standard 186s cam in or very close to it. (www.crowcams.com.
#13 Posted : Friday, 16 December 2005 6:26:11 AM(UTC)
Hi James,
The 202 head will bring your compression back down into the 9's (9 point something) so you may well get away with 96 octane PULP.
Your 161 head has larger valves (and probably bigger ports too) so you will sacrifice some HP.
If you have
Edited by user Friday, 16 December 2005 6:27:20 AM(UTC)  | Reason: Not specified
#14 Posted : Friday, 16 December 2005 6:29:05 AM(UTC)
I found this link after postin the above...it is a very good explanation of porting/vlaves, etc for heads and how they work.
http://www.racetech.com.au/custom.htm
Cheers...Dave
jimbobhtute Offline
#15 Posted : Friday, 16 December 2005 7:13:17 AM(UTC)
jimbobhtute
Cheers dave, I'll have a look at that.
james
1970 HT UTE
jimbobhtute Offline
#16 Posted : Friday, 16 December 2005 8:52:55 PM(UTC)
jimbobhtute
Can anybody explain the main differences between the HQ/HJ/LJ 202 Head I have here and a 186s Head setup, in relation to valve, port size and other dimensions.
cheers james
1970 HT UTE
jimbobhtute Offline
#17 Posted : Saturday, 17 December 2005 7:31:07 AM(UTC)
jimbobhtute
anybody????
1970 HT UTE
#18 Posted : Saturday, 17 December 2005 9:22:05 AM(UTC)
Hi James,
No idea on valve or port size but all other critical dimensions (including Combustion Chamber size) are identical bar one. The 202 heads use longer pushrods due to the non-adjustable rockers.
Basically, and with the exception of the pushro
jimbobhtute Offline
#19 Posted : Saturday, 17 December 2005 9:47:15 AM(UTC)
jimbobhtute
Thanks Dave
1970 HT UTE
jimbobhtute Offline
#20 Posted : Wednesday, 18 January 2006 11:14:20 PM(UTC)
jimbobhtute
Posted - 15/12/2005 : 12:39:49 PM
Hi jimbobhtute.
Guest (8)
This page was generated in 0.098 seconds.
