#1 Posted : Sunday, 18 December 2005 8:14:28 PM(UTC)
Merry Xmas everyone,
My question is will a pair of standard HQ V8 front coil springs fit into a HT Holden front end, I'm also told the HQ stubs will fit the HT frontend.
Which ball joints would I use for the HQ to HT stubs, HQ or HT.
I have a Castlemaine Rod Shop HQ Stub to VP Commodore disc brake conversion kit to install as I want to use the Commodore 15'' rims on my Plymouth.
Regards
Elvis.
EAP
Dylan Offline
#2 Posted : Sunday, 18 December 2005 8:57:45 PM(UTC)
Dylan
HQ and HT stubs are exactly the same, the casting looks different, but they are the same part, all ball joints from HR to WB are the same
#3 Posted : Sunday, 18 December 2005 9:33:05 PM(UTC)
keep us updated with the stub swap :) i'm thinking of the same thing for my hk...
#4 Posted : Sunday, 18 December 2005 10:43:24 PM(UTC)
Thanks Guys, I'll start setting it up tomorrow.
No more work for 5 weeks I'm on holidays.
EAP
80737k Offline
#5 Posted : Tuesday, 20 December 2005 6:47:28 AM(UTC)
80737k
is vp stud pattern the same as hq?
Ooroo
Fossil fuels are YUMMY !
#6 Posted : Tuesday, 20 December 2005 9:04:25 AM(UTC)
No, VP and HQ - WB are different and not interchangable.
If I remember rightly, Elvis is doing a Commodore upgrade/comversion on his front end so he will have matching stud patterns.
Cheers...Dave
#7 Posted : Tuesday, 20 December 2005 9:17:47 AM(UTC)
Hows this for even more confussion I had a HQ Ute and wanted to sell the alloy mags that were on it so a lady with a WB comes along wanting to by them.
We tried to put them on her ute there and then but they would'nt fit either end of her WB and I still
#8 Posted : Tuesday, 20 December 2005 9:20:16 AM(UTC)
Someone must have played with the stud pattern on either your HQ or her WB. All these models use the Chev PCD of 5/120.65mm (or 5/4¾").
Cheers...Dave
#9 Posted : Tuesday, 20 December 2005 11:15:27 AM(UTC)
Hi QUTE, I think you should check your facts - Forum Mechanic.
No one played with either studs pattern after I sold the alloys to a chappy with a HZ I then purchased a set of series 61 chrome Gragars to fit the my HQ and was told the stud patern was HQ.
#10 Posted : Tuesday, 20 December 2005 12:50:24 PM(UTC)
Elvis,
Read my reply again and also my reply to your other posy on this subject..
Cheers...Dave
#11 Posted : Tuesday, 20 December 2005 9:43:41 PM(UTC)
Dave is right on this one.
Adding to this DBA will supply HQ-WB front rotors/hubs drilled to suit the Commodore stud pattern if you ask them. Maybe the potential buyer of your wheels had her stud pattern changed by a previous owner & didn't know it
#12 Posted : Tuesday, 20 December 2005 9:47:03 PM(UTC)
I really dealt it.
EAP
This page was generated in 0.301 seconds.
