#1 Posted : Saturday, 24 December 2005 10:49:03 PM(UTC)
FROM CHRIS VIA EMAIL:
Hi, just recently i changed the front and real main seals in an xp 170cu in motor and during the process i had to remove the harmonic balancer, after taking it off i realised it was in two pieces seperated by a rubber/plastic damper and there were no alignment markings on it. as you can guess this could pose a problem puttin it back together. the inner ring has a keyway in it so it can only go on one way but the outer ring has the timing markings on it. the way i put it back on was the i knew the car was set to 10degrees BTDC so i put it on tested the timing, rotaed the outer ring, tested timing again and so on untill it was back to saying 10 degrees BTDC. But i was just wondering, how owuld i know if it was correct to begin with? i was wondering if there are supposed to be timing marks on it that maybe i can't see because of paint or something, or if you's have a way of aligning. Any advice would be greatly appreciated.
thanks and regards
chris
Fastlane Administrator
#2 Posted : Monday, 26 December 2005 12:18:51 AM(UTC)
your best bet would be to get another one and line the key holes up to see where the marker is otherwise you will never know where it was.
#3 Posted : Thursday, 5 January 2006 12:30:19 PM(UTC)
I don't think it is supposed to be in 2 pieces.
#4 Posted : Friday, 6 January 2006 7:50:30 AM(UTC)
Outer ring should be bonded to inner ring,chances are its going to come off while youre driving,best to get a change over from bursons or repco.
