JUST HAD MY HZ AIRCON REGASSED, BUT ITS NOT GETTING COOL INSIDE, COMPRESSOR SUCTION PIPE COLD, DISCAHRGE PIPE HOT, BUT NO COOL AIR INSIDE, ANY IDEAS/
If you're in Qld chances are it's working fine but it just can't keep up with the heat at the moment - I can't find anything to stop my pits from dripping!!
Anyway, back to the topic, yeah go back to the place that regassed it cause the gas is dangerou |
___________________ - HJ turbotonner looks and goes like a sneezing rhino on heat! - |
You have been a member since:: 1/03/2005(UTC) Posts: 1,991
Have you got all the right vents open?
all air con vents open, I degassed and cleaned tx valve, regassed, works but only ok, when coverting to 134a from r12 does one need to change the tx valve to operate at a different schedule due to pressure differences between 134a and r12. There must be s
I did read somewhere there is a number of important if minor differences in these valves. I would suggest you see a air con guy, or do a search in aircon either here or oldholden. can't remember where i saw the writeup.
make friends with a fridgy and get it charged with r12 these guys drain the gas from old fridges and store it, better in your car than floating in the air...
My guess would be to replace TX valve. To get air con really cold vacuum system for 1.5 hrs to get all moisture out of system then regass, we used to get down to 1 degree.
