Hi
Advice Please
It it easy to put a red motor in FX ute
what modifications are need
I already have a red gearbox connected by adapter plate to a grey engine in my fx ute and now want to pur a red motor in
do ineed an engineers certificate
any advice apreciated
thanks
It depends on what state as to what rules you have to follow.
The usual way is to fit a HR front end and move the engine mounts to suit the gearbox crossmember.
If you fit a 138 or 149 red motor you will be fine as far as I know! |
Thanks: 1 times Was thanked: 638 time(s) in 599 post(s)
Go and find a 138 red motor. I don't think you have to Engineer these. I think in NSW you can get away with a 149 also. You'll need side mounts, but Rare Spares sell either mounts to weld on or x-change crossmembers with the mounts already on.
_______ |
what state? a trip to their website will help. Whats the tare weight of FX? Edited by user Monday, 26 March 2007 7:03:26 AM(UTC)
| Reason: Not specified
Hi State is Victoria. Tare (kerb) weight is 2230lb (1012kg) thanks for you help
quote: Originally posted by FastEHHolden
