#1 Posted : Wednesday, 11 April 2007 1:01:05 AM(UTC)
are relays to the starter supposed to be hot all the time ? mine was and sometimes it would fail to crank the 202 so i disconected it and put the wires back to normal cheers and thanks
#2 Posted : Wednesday, 11 April 2007 3:21:14 AM(UTC)
Hi john.
The relay should not get hot all the time, it only conducts current when you are cranking. It's probably wired incorrectly.
Dr Terry.
#3 Posted : Friday, 13 April 2007 2:13:00 AM(UTC)
thanks dr terry but i have wired it every which way and it will only start in one position and stays hot anyway since i disconected the altinator light goes out completely when i start it up cheers
