les Offline
#1 Posted : Monday, 25 June 2007 7:15:42 PM(UTC)
les
We recently received 2 decals from GM with no part number, we do not even know if they were ever used on Hz’s. (They were samples someone had hanging around) can anyone identify them http://www.rsp.net.au/zforles/hz%20decal.jpg
#2 Posted : Monday, 25 June 2007 9:22:52 PM(UTC)
Hi les.
The top one is off an HZ V8 air cleaner lid.
AFAIK, the bottom wasn't used in production.
peterwmh Offline
#3 Posted : Tuesday, 26 June 2007 5:18:07 AM(UTC)
peterwmh
As the doc said, however I will add that red 6s (well at least on my very very original HZ SL) also has the top decal with 3.3 litre written in the same colouring, see pic below. Cheers Peter
[IMG]http://i6.photobucket.com/albums/y247/peterwmh/IMG_150
les Offline
#4 Posted : Tuesday, 26 June 2007 5:56:59 AM(UTC)
les
Thanks Guys
We have sorted the top one out it’s really the bottom one that causing the problems, maybe Dr Terry is correct the may not have been used in production
Les
