We recently received 2 decals from GM with no part number, we do not even know if they were ever used on Hz’s. (They were samples someone had hanging around) can anyone identify them http://www.rsp.net.au/zforles/hz%20decal.jpg
Hi les.
The top one is off an HZ V8 air cleaner lid.
AFAIK, the bottom wasn't used in production.
Dr Terry |
As the doc said, however I will add that red 6s (well at least on my very very original HZ SL) also has the top decal with 3.3 litre written in the same colouring, see pic below. Cheers Peter
[IMG]http://i6.photobucket.com/albums/y247/peterwmh/IMG_150 |
202 and three on the tree, can't get more Aussie than that!! |
Thanks Guys We have sorted the top one out it’s really the bottom one that causing the problems, maybe Dr Terry is correct the may not have been used in production Les
