Hey, im just wondering if a wb one tunner aircond compressor of a blue block 253 fit a vb red block 253. Just wondering as i no of were one is. I have all the aircond parts apart from compressor for my car.
If not, would it still work if i happen to switch over from a wb one tunner blue block 253 would it work with my current aricond set up.
Im just trying to find out due to the fact that im getting a wb blue block 253 for a really cheep price, and if i wont i can get the compressor for free.
Hi LPGPIG.
You don't mention what model your car is.
The only compressor used for genuine factory-fitted A/C for HQ -WB & VB/VC is the GM A6 (branded either Frigidaire, Delco or Harrison). VH onwards used Sanden compressors.
The GM A6 compressors |
Hi LPGPIG.
You dont mention what model your car is.
Ive got a VB SL. So that means that i should be right if one day i happen to wont aircond in my car. Thanks for that mate.
Cheers from justin
Hi LPGPIG.
Retrofitting factory A/C to VB/VC requires some serious surgery. The compressor & brackets are the easy part. New holes need to be cut in the firewall & old ones filled in. Some serious wiring & plumbing is also required.
Dr Terry |
Hey DR Terry, i did add that i had all the other aircond gear, but i think i forgot to say that my car was factory fitted with aircond, but when i got the car i was just missing the compressor clutch.
What i have done, is that i have taken out all on t
you MUST get the condenser and in fact the whole setup thoroughly cleaned internally because there can be rust and other crap inside that will destroy the sytem or stop it working. You cannot reuse the drier (the cylinder looking black thing with the wind
Thanks for that mate. Im not planning on using it at the moment. Just wonted to know if it fitted for refrence later on, as i picked it up for nothing. Its another part that cost a bit and is hard to find, and can always come in handy. Cheers Edited by user Saturday, 24 November 2007 11:09:42 AM(UTC)
| Reason: Not specified
