hi,
i`m converting my hk to hq brakes all round, can i use hq booster & master cylinder or should i use hk booster with hq master cylinder ?
thanks in advance for any help
BUMP!!!
I would also like to know the answer to this. I am running a HK, with HQ front brakes and HK rear brakes. HK booster and Master.
No matter what I do, I still get a spongy pedal. The thing will stop on a dime, but I just cant loose the spo
Hi Guys.
Keep the HK booster & master cyl, you'll gain nothing by changing to the HQ set-up. Just change the front brakes. Both master cyls are 1" & the HK bosster fits the firewall & pedal more easily.
Paul, did you just convert or change something |
Hi Guys.
Keep the HK booster & master cyl, youll gain nothing by changing to the HQ set-up. Just change the front brakes. Both master cyls are 1" & the HK bosster fits the firewall & pedal more easily.
