basketcasebear Offline
#1 Posted : Monday, 24 December 2007 12:30:29 AM(UTC)
basketcasebear
started doing brakes on conversion,
and it has a spring contraption, conected to the diff, and body,
have been told it is for more braking pressure when under load,?
problem, could not get one pipe out of spring gismo, so have connected system in straight, without regulating gizmo,
Q, will this mean everytime I hit the anchor,s my back wheels will lock up?
If so, is there any after market type gismo, i may be able to use? should i need too?
thankee fur yur assistance.
ptpro
madmax transit, 308t400 campervan
DOH!!!
HQ SAND MAN Offline
#2 Posted : Monday, 24 December 2007 12:39:59 AM(UTC)
HQ SAND MAN
hey there mate , will find out for ya tomorrow when i get too work and ask the mechanics ,, have a good one ,, ps still carnt work out this photo thing
#3 Posted : Monday, 24 December 2007 5:52:52 PM(UTC)
Hi basketcasebear.
It sounds like you are describing a load sensensing proportion valve. These were fitted standard to late HZ & then WB One-Tonners & all utes from VG to VS. Many other brands of commercials also have them.
What car do you have & wh
#4 Posted : Monday, 24 December 2007 11:57:43 PM(UTC)
basketcasebear
Hi dok Terry,
it is a 3.35 AU diff in a 98transit,
transit has one as well,,cant decide which one to use, au or transit, probably use au one, as will be easier to get these in future.
I was trying to figure out, how to set it up properly, for height an
DOH!!!
#5 Posted : Wednesday, 26 December 2007 11:06:44 AM(UTC)
i moved a pipe off the disk brake assembly, and lost the little washer from it,
what would they be called?? pipe washer? need to order one?
might be a stupid Q, i suppose?
thanks already
#6 Posted : Wednesday, 26 December 2007 4:44:07 PM(UTC)
Hi Mr Bear.
Do you mean the copper washer where the brake hose attaches to the caliper. They are just called copper washers & the size should be 10 mm.
#7 Posted : Wednesday, 26 December 2007 6:09:29 PM(UTC)
basketcasebear
yep, thats it dok terry,
Copper??
I remember it, did not think it was metal? but now i know, should be able to get one, did not even think it had dropped off, untill i filled the brake fluid up, and found one side leaking.
thanks
ptpro
madmax trans
DOH!!!
gmholdman Offline
#8 Posted : Wednesday, 26 December 2007 9:04:42 PM(UTC)
gmholdman
Bear, purchased 4 washers on the week-end from A.B.S =$1.00 EACH. al.
#9 Posted : Wednesday, 26 December 2007 11:37:59 PM(UTC)
basketcasebear
thanks GM,,will orjaganize said washers tomoro!
ptpro
DOH!!!
This page was generated in 0.066 seconds.
