Gday my mate has just purchased a 11-84 VK calais it has HDT build # tag under bonnet build # 395 or 393 it was night when he loaded it on transport so wasnt quiet able to see clearly it has HDT wheels and HDT badges on body and HDT director on dash the VIN is 8k19t2u915743k if anybody could help with some info it would be appreciated Cheers Adam
Hi Adam
If it really was an HDT Calais it wouldn't have a VIN beginning with 8K19T2U.......
A 308 VK Calais made in 11/84, should read 8X19TE......
It could be still an HDT, it's just that it's an Executive base not a Calais.
Dr Terry |
Hi Adam
If it really was an HDT Calais it wouldnt have a VIN beginning with 8K19T2U.......
It could be still an HDT, its just that its an Executive base not a Calais.
Dr Terry |
11/84 with the number 915743 would be a J tag, not an L tag (they were in the L1xx range)
Straight away that says it's not a calais, as all calais were built in Elizabeth.
I went through Chris Sewell's "HDT build numbers bible" from J905xxx to J930x |
Straight away that says its not a calais, as all calais were built in Elizabeth.
I went through Chris Sewells "HDT build numbers bible" from J905xxx to J930xxx |
sounds like a 3.3 executive
8K19T = K gives it as SL (or SS, or exec - they were K based trim levels). The T denotes 5.0L (308) V8.
So it is a V8, but not a Calais.
A lot of people aim to ac |
