help started the vn commie up this morning first pop drove it across the road to a mates driveway turn it off had to get another car out thats why anyway went back to start the commy it fired up first pop again then it **** it self anyi have a clue why it wont go?oh its got fuel also its on gas aswell i cant hear the fuel pump start up when i turn the key on or the cutoff valve click on fuse 4 f/pump is ok whats wrong??thanks in advace guys.
I know crap about any thing past 1980. As 2 intellegent people told me when I was young.
Its only 1 of three things Electrical Mechanical Or Fuel. And If you can Identify the problem you can fix it.
Id check for spark. Plug an old plug into the pl |
If its not broke it will be soon |
Reg your commie is so smart that it tell you whats wrong with it itself under the glovebox in the far corner you will find a plug with about 10 or 12 wires that nothings pluged into it at one end youll find a black and a black/white wire bridge these |
On The Other Hand There's Finger's |
Reg your commie is so smart that it tell you whats wrong with it itself under the glovebox in the far corner you will find a plug with about 10 or 12 wires that nothings pluged into it at one end you'll find a black and a black/white wire bridge thes |
can almost guarentee its either the crank angle sensor ( if its just turning over and doesnt even sound like its gonna start for sure ) or the fuel pump if it sounds like it wants too go but just wont
yeah if u turn the key it firs up 4 a second and i cant hear the fuel pump kickin anymore but its on gas aswell but still wont start then again u should be able 2 hear the safty valves kickin when u turn the key but they dont anyi got a wire diagram 4 a v
gas will be powered by fuel pump power. Check fuel pump by listening in the filler while ignition gets turned on,don,t crank.pump will only operate for about 4 seconds then will automatically shut down till ignition is turned off again.Ill agree with HQ t
gas will be powered by fuel pump power. Check fuel pump by listening in the filler while ignition gets turned on,don,t crank.pump will only operate for about 4 seconds then will automatically shut down till ignition is turned off again.I'll agree with HQ
Hey mate had similar problem was a fuel pump relay sensor and fuel pump hope this helps might be able to get away with the sensor its cheaper best of luck
Thanks: 8 times Was thanked: 16 time(s) in 14 post(s)
if i thought i could help someone who had a vn commy that was waiting for say, 14 months, before he fixed it or got some help, i wouldve suggested burning it, and hanging oneself from the truss in the shed that housed it since the sqft rate wouldve exceed
