my LC GTR has a gearbox which has a second shift lever for reverse, I am told only 5 were put in production LC GTR`s . Can anyone verify this?
It sounds like you have an Aussie 4 speed box with a shifter designed for a 3 speed box so a second lever has been added to the one linkage that only does one gear (reverse).
Do you have photo's of this shifter?
Do you have photos of this shifter?
Hi Gibbo.
You have been fed BS.
What you have there is a Speco aftermarket shifter designed for any Holden Aussie 4-speed.
A company like Holden would not build only 5 of anything to go into production.
Most LC GTRs were originally fitted with |
Hi Gibbo.
What you have there is a 'Speco' aftermarket shifter designed for any Holden Aussie 4-speed.
Most LC GTRs were originally fitted wi |
2/71 Date of manufacture . I was told they were developed for racing and 5 were put in production cars as a trial Gibbo
If your car was built in 2/71 it would have been fitted with an Opel 4 speed in the factory. They were racing GTR XU1s not GTRs so any "experiment" would be on an XU1.
Plus the Aussie 4 speed was still 4 months away, so there would not have been any pr
is it VF next year? or is that just an example?
Thanks that has answered my question. Just need to change the shift and she back to all original.
Hi gibbo.
It depends what your mean by 'original'.
If you fit a factory shifter it will back to factory standard, but that was not 'original' for a 2/71 LC GTR, because the Aussie 4-speed wasn't factory-fitted until 7/71.
A 2/71 LC GTR was 'origi |
Hi gibbo.
It depends what your mean by original.
If you fit a factory shifter it will back to factory standard, but that was not original for a 2/71 LC GTR, because the Aussie 4-speed wasnt factory-fitted until 7/71.
A 2/71 LC GTR was originally |
It is an opel gearbox in the car. I just had never heard of this before and wanted to confirm it.
Gibbo
One other thing LC GTR XU1`s were introduced in June 1971. this was another factor that had me asking questions about the shift being use on the GTR. GTR`s were raced as well.
Sorry 19th August 1970 the GRT XU1 was officialy launched.
I cannot see how yp could have a second lever on an Opel for reverse. There are two rods on an opel, one goes back and forthe, the opther moves a selector in and out. The back and forthe selects 1/2, 3/4 or R and the other moves a rod in and out of the bo
