http://cgi.ebay.com.au/H...VWQQrdZ1QQcmdZViewItem.
I thought weight was derated after 9/75???? this is 10/ 75., if it is one.......?? A1 Bogan. |
only 5 cars to go before the EH...
A1 Bogan. |
Thanks: 1 times Was thanked: 613 time(s) in 580 post(s)
Only derated for XX7. If it's an XU3 will still be 2200kg for a V8.
Only derated for XX7. If its an XU3 will still be 2200kg for a V8.
were the XU3 2200 kg for all sandmans up to HZ? is the van in the link a SANDMAN? A1 Bogan. Edited by user Thursday, 27 March 2008 10:02:55 PM(UTC)
| Reason: Not specified |
HJ-HZ V8 XU3 Sandmans are 2200kg. Prior to 1976 model there was no XU3, only XX7 and these were 4850lb for V8 HQ and 2200kg for V8 HJ ie no derating. HJ-HX 6cyl XU3 are 2155kg (no 6cyl HZ Sandman).
_____________________________________________________ |
ok, how do you tell the difference between a V8 2 seater belmont and a XU3 sandman (apart from the tyre placard sticker and roof lining, interior light) A1 Bogan. Edited by user Thursday, 27 March 2008 10:11:13 PM(UTC)
Roof lining and interior light switches dont even guarantee Sandman as both were options on base model. There are a few other telltales though, like HX,HZ trim (sometimes), floor shift (standard on Sandman but again optional on base model). XU3 are very h |
Roof lining and interior light switches don't even guarantee Sandman as both were options on base model. There are a few other telltales though, like HX,HZ trim (sometimes), floor shift (standard on Sandman but again optional on base model). XU3 are very |
i looked at a van about 4 months ago
HX, 1977, WM 70, adelaide car L31, M21, 2 seater White on black trim GTS dash, full head lining, i had the opportunity to buy, but declined because of 2200 GVM.
was that a mistake? how do i prove / disprove? |
If it had black trim then you can actually tell with this one. If it was a Sandman it would have been 18V. If not, 19V.
