I know the following engine number (186P370382) is for a 186s but can a model (HK-T-G ect) or year be determined from the engine No, as the engine is not with me & I can't check the date codes.. thank's Kevin
HOLDEN The Great Way to Move |
Hi Kevin.
That engine number is not for a 186 S, it is for a standard 186. A true 186 S, actually has a 186S prefix in the HK/T/G series.
That number places it in very late HT production, probably in the last month.
Dr Terry |
thanks
thank's
Terry, Im chasing some info on my car its a HG GTS monaro if i supply the numbers can you help me out, or know anyone that could. Cheers Daniel.
Terry, I'm chasing some info on my car it's a HG GTS monaro if i supply the numbers can you help me out, or know anyone that could. Cheers Daniel.
Post them here and youll get help.
Post them here and you'll get help.
