Hi guys, Need help with my trans cross member on WB holden ute,ive put in a turbo 400 trans,so old cross member from ute doesnt fit(was trimatic)was told to get a cross member from a statesman which i have done,now the statesman cross member is to wide to bolt up and wont line up any where, Can anyone help me please?what cross member do i need to use?also its got an adapter plate to fit turbo trans to 308 as it wasnt turbo bolt pattern.
youll need to cut the statesman crossmember to suit but make it exact cuts on both ends and redrill,,just use nuts n bolts to secure,you can try to track a ute t400 crossmember but these are hard to find and the fact that you are using a adapter between t
Make sure it's from a Statesman that originally had a TH400 too (ie HJ through to mid 1979 HZ). I've done exactly what piztoff says too, but I removed the captive nots off the ends I cut off and welded them over the new holes to suit the ute/tonner.
__ |
Make sure its from a Statesman that originally had a TH400 too (ie HJ through to mid 1979 HZ). Ive done exactly what piztoff says too, but I removed the captive nots off the ends I cut off and welded them over the new holes to suit the ute/tonner.
____ |
HI sikute, when I fitted a T400 in my ute I retained the original crossmember but just welded a small tag (about 3x3 inch, quarter plate) on the front with pre drilled holes to pick up the mounts on the trans. That has been there for 5 years now, with n
TH400 mounts are not forward of the crossmember. They are actually on the crossmember. I think you are referring to TH350.
awesome thanks for your help guys,pretty much what i started to do before i read this(cut ends each side to shorten)but didnt wanna butcher a good cross member if it wouldnt work after all that. "Byron" was our last comment to me or some ones elses? mine
Hi Sikute.
A WB TH350 crossmember will not fit a TH400.
Dr Terry. |
My comment was for wannabe351. Dr Terry is coorect, youll need an earlier Statesman (or any other factory TH400) crossmember.
My comment was for wannabe351. Dr Terry is coorect, you'll need an earlier Statesman (or any other factory TH400) crossmember.
ok thanks again guys,your a great help,ill be on the search again by sounds of it!!!
you can just drill 2 holds about 45 mm back from the trimatic ones to make the T400 fit.
It won't be a true T400 crossmember, because it will lack the strengthing plates, but it will get you mobile to get to muffler shop etc.
He who hesitates, -Mas |
It wont be a true T400 crossmember, because it will lack the strengthing plates, but it will get you mobile to get to muffler shop etc.
He who hesitates, -Mast |
