Hi Guys I have bought an LC Torana and was looking at converting her to a 253, well i just found out by the DPI that its a no go, as i have to modify the steering arm (move it over) for it to fit and they wont allow this in WA,, so im stuck with a 6cyl.I was looking into getting a 186 and was wondering could anyone tell me what work i would need to do for it to sound like a V8 and go pretty hard , Cheers , Sandy
<i>sjhorner</i> |
<i>sjhorner</i> |
Use a 202. Cheaper and more torque. Itll never sound like a V8, but you can make it go hard.
Use a 202. Cheaper and more torque. It'll never sound like a V8, but you can make it go hard.
doesnt castlemane shop still do the 221 stroker cranks for the 186. get a head gasket from a vk so you can drill your 186 to suit the water ports to fit a 12 port head.look here http://www.efihardware.com/efi_throttle.html for some injsection. your 186 wi
thanks for the info guys will look into it
<i>sjhorner</i> |
<i>sjhorner</i> |
A V6, VL RB30, 245 or 265 Hemi are also viable swaps but the last RB30 powered LJ that I saw had some of the firewall cut so it would fit.
If at first Edited by user Sunday, 8 June 2008 4:33:04 AM(UTC)
| Reason: Not specified |
i have a 202 with YT head and LJ sump. $250. Rivervale
