nick ht Offline
#1 Posted : Tuesday, 10 June 2008 12:32:13 AM(UTC)
nick ht
anyone see any problems putting a vk commodore 304/308 into a ht
#2 Posted : Tuesday, 10 June 2008 1:07:05 AM(UTC)
Only that youll need to comply with emmissions regs for the VK motor - like the charcoal canister, PCV system, vac-spark-advance restrictions etc.
Mechanically the bolt up is no probs with the right HT 253/308 sump, oil pickup, dipstick and engine moun
#3 Posted : Tuesday, 10 June 2008 1:07:05 AM(UTC)
Only that you'll need to comply with emmissions regs for the VK motor - like the charcoal canister, PCV system, vac-spark-advance restrictions etc.
#4 Posted : Tuesday, 10 June 2008 2:52:21 AM(UTC)
Nothing wrong with it but has emissions pitfalls in some states. Best bet is if it's cheap buy it and rebuild it using an earlier block. You'll find someone who'll do a deal on the VK block for a red block. The black motor will still have some usefull stu
#5 Posted : Tuesday, 10 June 2008 2:52:21 AM(UTC)
Nothing wrong with it but has emissions pitfalls in some states. Best bet is if its cheap buy it and rebuild it using an earlier block. Youll find someone wholl do a deal on the VK block for a red block. The black motor will still have some usefull stuff
