#1 Posted : Saturday, 14 June 2008 5:03:13 AM(UTC)
i am trying to start a 138 grey motor. it hasnt been started for a few years. It was a good runner before it went into storage. I have changed plugs oil point leads etc. Electrics are ok, it wants to fire but just dosent. what else can i do
#2 Posted : Saturday, 14 June 2008 6:48:05 PM(UTC)
check for spark , put on a timing light or disconnect a lead slightly, check that the carby is spraying fuel,if all else fails buy a can of `start ya bastard` or aero start, squirt in the carby and turn over.
#3 Posted : Saturday, 14 June 2008 7:42:33 PM(UTC)
thanks,
I know i have spark, havent done the timing light, i will get the aero start
#4 Posted : Saturday, 14 June 2008 7:47:41 PM(UTC)
good luck
#5 Posted: : Saturday, 14 June 2008 11:31:29 PM(UTC)
is there anyway i can roughly do the timing, i am not sure how to do it
thanks
#6 Posted : Sunday, 15 June 2008 3:32:32 AM(UTC)
have you changed the fuel, if not how long has it been there?
doesnt last long these days and stinks when it gets old, you may need to drain the old out of tank and replace
#7 Posted : Sunday, 15 June 2008 3:32:32 AM(UTC)
doesn't last long these days and stinks when it gets old, you may need to drain the old out of tank and replace
David Offline
#8 Posted : Sunday, 15 June 2008 9:25:47 AM(UTC)
David
I left a 179 for about a year and then couldn't start it. During my efforts to start it I pumped in plenty of juice. This had the effect of rinsing all the oil off the rings/bore, so there was no compression.
Once I squirted a bit of oil into each cy
David Offline
#9 Posted : Sunday, 15 June 2008 9:25:47 AM(UTC)
David
I left a 179 for about a year and then couldnt start it. During my efforts to start it I pumped in plenty of juice. This had the effect of rinsing all the oil off the rings/bore, so there was no compression.
Once I squirted a bit of oil into each cyl
#10 Posted : Sunday, 15 June 2008 7:20:52 PM(UTC)
the motor hasnt been started for over 20 years! the car had been sitting in a shed. i didnt drain the fuel, i topped it up. (the lazy way)
#11 Posted : Monday, 16 June 2008 5:57:30 AM(UTC)
I started a vauxhall L series circa 1949 basically engish FJ last yr that was last run in 1977, hooked up gravity feed to the carby,
lot of huffing, smoking and rattles for about 15 mins then oil circulated and engine heated a bit and it idled roughly,
#12 Posted : Sunday, 22 June 2008 5:10:37 AM(UTC)
I got a 1965 Corona started out the farm the other day. It apparently hadn't been started for 12 years, was sitting in the shed when I bought the place. Put a new battery in, tipped some fresh fuel down the carby and 60 seconds later it's sitting there id
#13 Posted : Sunday, 22 June 2008 5:10:37 AM(UTC)
I got a 1965 Corona started out the farm the other day. It apparently hadnt been started for 12 years, was sitting in the shed when I bought the place. Put a new battery in, tipped some fresh fuel down the carby and 60 seconds later its sitting there idli
This page was generated in 0.065 seconds.
