I am trying to find out who is widely known to be the authority on all things Torana..... does the Torana world have their very own expert?
I need some info on a LC GTR but not sure who to ask... if anyone has some contact details I would appreciate the info
Ask here or on www.gmh-torana.com_______________________________________________________ If we all had the same (good) taste, who would buy all the Fords? |
anyone? cant logon to the torana site ... you have to be a member.... guess im impatient... any help would be appreciated
ask here then and Ill find out...or you could use the "my assistant" search on the torana site....what is it you want to know.
ask here then and I'll find out...or you could use the "my assistant" search on the torana site....what is it you want to know.
ok... I have an LC GTR that has had the vin and body id tag removed... the safety compliance plate is still on the car... the car is a 6/70 build and holden do not have records back that far... does anyone have a list of GTRs that I can track back from th
ok... I have an LC GTR that has had the vin and body id tag removed... the safety compliance plate is still on the car... the car is a 6/70 build and holden do not have records back that far... does anyone have a list of GTR's that I can track back from t
I doubt very much you'll find it on the microfiche if indeed they go back that far. The only hope is if you know who the selling dealer was. The problem is the GTR will have very few mechanical options and it will be hard to track it on the fiche based up |
I doubt very much youll find it on the microfiche if indeed they go back that far. The only hope is if you know who the selling dealer was. The problem is the GTR will have very few mechanical options and it will be hard to track it on the fiche based upo |
From GMH-Torana.com: Unfortunately the records do not reference the ADR/Chassis number. Your only slim chance is if the car still has its original engine/number and someone goes through the list looking for that....but it's just a slim chance because a Edited by user Saturday, 21 June 2008 8:34:20 AM(UTC)
| Reason: Not specified
From GMH-Torana.com: Unfortunately the records do not reference the ADR/Chassis number. Your only slim chance is if the car still has its original engine/number and someone goes through the list looking for that....but its just a slim chance because a Edited by user Saturday, 21 June 2008 8:34:20 AM(UTC)
another reply:
if he take the adr tag off the car and looks on the back of it the vin number will be on there, ingraved if is adelaide or writing if its brisbane.
cheers john
quote: Originally posted by Byron Rich
Im not sure if the LC/LJ fiche has paint and trim recorded. Do you know what colour th
I'm not sure if the LC/LJ 'fiche has paint and trim recorded. Do you know what colour
quote: Originally posted by FastEHHolden
another reply:
I forgot about the back of the ADR tag. If you pull it off the last 3 digits of the PSN will be on there, and then just look through the fiche for a PSN around that time (6/70 or 7/70 on the fiche) and you'll have the car nailed. You'll have to make up th |
I forgot about the back of the ADR tag. If you pull it off the last 3 digits of the PSN will be on there, and then just look through the fiche for a PSN around that time (6/70 or 7/70 on the fiche) and youll have the car nailed. Youll have to make up the |
should be last 4 difits of PSN etched on the back if Adelaide and black marker if Brisbane, ADR will tell which, "A" for Adelaide "B" for brisbane, microfiche doesnt have body number or colour/trim details and as said before only some engine numbers you
should be last 4 difits of PSN etched on the back if Adelaide and black marker if Brisbane, ADR will tell which, "A" for Adelaide "B" for brisbane, microfiche doesn't have body number or colour/trim details and as said before only some engine numbers you
Only the last 3 digits in black marker on the back of Brisbane ADR tag. I've got probably 30 or so here and they are all the same. Have about 15 or so Adelaide tags and none of them have anything on the back of the ADR tag. Sydney and Melbourne blank also |
