Fastlane
Holden Forums
Buy, Swap & Sell - Holden
Wanted - green speedo gear for Trimatic
Hi guys... I have just thrown a 3.08 LSD into my ute and the speedo is up the creek. So I need a Green speedo gear for a trimatic. It has 21 teeth on it. If you got one you want to part with let me know. Cheers [email protected] |
______________________________________ Speed has never killed anyone, suddenly becoming stationary... thats what gets you |
sure do mate. have one here. $20 inc post.
email me if you like
j_ackland(at)aapt(dot)net(dot)au
cheers jason |
Hi Ayios, I don't have a workshop manual with me at the moment but from memory, a Trimatic with a 3.08 diff should have a blue speedo driven gear. Could be wrong though!
Hi Ayios, I dont have a workshop manual with me at the moment but from memory, a Trimatic with a 3.08 diff should have a blue speedo driven gear. Could be wrong though!
HI Rhys When I did the calcs it was either the green or the dark blue.... BUt worked out closer to the green... I guess I have to try and see. Anyone got a dark blue one as well??
had a squiz at mine and nah sorry no dark blue ones...... |
Hi Ayios, It really depends on what tyres you have fitted. If you had stock profile tyres then the 22 tooth blue would definitely be the one. Maybe just fit the green one and see how you go. If it reads 5km/h too fast then you can fit the dark blue one.
Thanks: 1 times Was thanked: 607 time(s) in 574 post(s)
Not exactly. HQ V8 trimatic with 3.08 diff and "stock" tyres could have 21, 22 or 23 teeth gear ie green, dk blue or red dependant upon which tyre option was chosen for the car. Ayois has worked out from the factory tyre sizes and his tyres which is the c |
Fastlane
Holden Forums
