#1 Posted : Thursday, 16 December 2004 8:22:51 AM(UTC)
I’m having some problems with my VL commodore. It has a 6-cylinder EFI motor and has started to loose power occasionally. I first noticed it about 2 weeks ago going up a hill. Since then I have noticed it to loose power occasionally (only about 10 – 15 times) when I takeoff. I have recently replaced the fuel pump and fuel filter, and checked fuel pressure the other day, which was fine. Any suggestions on what could be causing this appreciated.
#2 Posted : Thursday, 16 December 2004 7:54:59 PM(UTC)
With all troubleshooting, do the simplist and cheapest things first.
In your case right now ! Replace the leads.
Cheers, John
#3 Posted : Thursday, 16 December 2004 9:19:14 PM(UTC)
Well if it's anything like the problem I'm having with my astra, keep the air con on and that should keep it from losing power. That's what I've resorted to doing at the moment.
#4 Posted : Thursday, 16 December 2004 9:19:14 PM(UTC)
Well if its anything like the problem Im having with my astra, keep the air con on and that should keep it from losing power. Thats what Ive resorted to doing at the moment.
#5 Posted : Friday, 17 December 2004 7:01:48 AM(UTC)
i agree with john, replace the leads plugs etc. Check the spark? Does it only happen when hot or cold?
#6 Posted : Saturday, 18 December 2004 9:49:47 AM(UTC)
Have a look at the computer (behind the passenger's kickpanel), turn the screw/adjuster to the right (I think) and turn the ignition on. It will flash at you, count the number of flashes of the red and green diode (from memory red is 10's and green is one
#7 Posted : Saturday, 18 December 2004 9:49:47 AM(UTC)
Have a look at the computer (behind the passengers kickpanel), turn the screw/adjuster to the right (I think) and turn the ignition on. It will flash at you, count the number of flashes of the red and green diode (from memory red is 10s and green is ones)
#8 Posted : Sunday, 13 March 2005 3:35:47 AM(UTC)
#9 Posted : Sunday, 13 March 2005 3:37:41 AM(UTC)
Taz2 Offline
#10 Posted : Sunday, 13 March 2005 4:54:46 PM(UTC)
Taz2
Checking the codes is your easiest option as Dave has suggested.
However, there is a procedure for checking them that you need to carry out....no good just going to diagnostic mode and looking at them there blinkin lights!!!
Either get a VL manual, or l
In thrust we trust
Taz2 Offline
#11 Posted : Sunday, 13 March 2005 4:54:46 PM(UTC)
Taz2
However, there is a procedure for checking them that you need to carry out....no good just going to diagnostic mode and looking at them there blinkin' lights!!!
In thrust we trust
#12 Posted : Thursday, 17 March 2005 11:47:05 PM(UTC)
Getting the VL wagon straight back on the Road.
Running a little late to catch the interisland ferry we managed to lose the rear window when the BBQ gas bottle pushed it out on a tight right hander. We found the glass still intact on the roadside and sa
#13 Posted : Friday, 18 March 2005 5:07:24 AM(UTC)
for all commodore codes i use this site.
very helpfull
www.commodorecodes.tk
#14 Posted : Saturday, 30 September 2006 3:53:25 AM(UTC)
hey ive just put a new set of extractors on my n/a 6 cyl vl commodore and my car seems to be overeaving ideling on 3000rmp does any one know what could be cuasing this
VL05 Offline
#15 Posted : Saturday, 30 September 2006 5:35:05 AM(UTC)
VL05
Needs to be tuned. Only VS or later ECUs will remap themselves.
WANTED: HQ/J/X/Z van in W.A., any condition pm me!
WANTED: GTS rims, seats and mirrors to suit HJ.
VL05 Offline
#16 Posted : Saturday, 30 September 2006 5:35:05 AM(UTC)
VL05
Needs to be tuned. Only VS or later ECU's will remap themselves.
#17 Posted : Monday, 12 February 2007 5:23:23 AM(UTC)
does anyone have a vl users manual handy. i jst swapped it to a manual and im havin trouble with some of the codes
#18 Posted : Wednesday, 21 March 2007 10:24:18 AM(UTC)
can someone tell me the codes for vl diagnostic pleaes
#19 Posted : Wednesday, 21 March 2007 10:34:02 AM(UTC)
best place is the library i got simaler prob
kristalleanne Offline
#20 Posted : Sunday, 30 September 2007 9:00:38 AM(UTC)
kristalleanne
my vl commodore just stopped yesterday while i was driving home in the rain,towed it home. it now runs like ****. any ideas????? ragards leanne
This page was generated in 0.161 seconds.
