#1 Posted : Monday, 11 August 2008 6:08:30 AM(UTC)
Im currently restoring a two tone vh sle. Im after any information regarding the size of the stripe, the spacing or any other information.
What Ive found out so far
The stripe originally was a sticker with a Holden part number. And as far as Holden knows no other information is available.
Any information would be greatly appreciated.
#2 Posted : Monday, 11 August 2008 7:18:46 AM(UTC)
In the VH, it was a mask, not a stripe/sticker.
There's seperate part numbers for the 9 sections of mask.
The mask was applied to the car, then paint applied to make the stripe, then the mask removed.
The original masks were done by a company in SA c
#3 Posted : Monday, 11 August 2008 7:18:46 AM(UTC)
Theres seperate part numbers for the 9 sections of mask.
The original masks were done by a company in SA ca
#4 Posted : Monday, 11 August 2008 7:26:17 AM(UTC)
spoke to cutler and they longer have that information available
#5 Posted : Monday, 11 August 2008 7:37:28 AM(UTC)
Looks like you'll need to find an orignal, non-repainted shadowtone VH, and using reference points every 100mm from nose to tail, measure the relative heights from a common point (like the swage line), and replicate that into your masks.
Mic
#6 Posted : Monday, 11 August 2008 7:37:28 AM(UTC)
Looks like youll need to find an orignal, non-repainted shadowtone VH, and using reference points every 100mm from nose to tail, measure the relative heights from a common point (like the swage line), and replicate that into your masks.
HZute-efi-VS5L Offline
#7 Posted : Monday, 11 August 2008 7:41:36 AM(UTC)
HZute-efi-VS5L
dunno if this is the one your looking for?
http://jason.shopholden....Path=39&products_id=164
jason
www.stickthisdecals.com.au
#8 Posted : Monday, 11 August 2008 7:51:38 AM(UTC)
thanks mick only problem is all the ones that are around are ****ed up lines a are all wrong its a tuff one chasing door and gaurd moulds and head lights new genuine if any one has
#9 Posted : Monday, 11 August 2008 7:55:55 AM(UTC)
Thanks jason they have commodore stripes but not the one i am after
