Hi All
I have recently bought a HJ GTS 4 door and have been reading some of the posts here.
I noticed that it has been said that the HJ/HX GTS only came out with a silver facia but I used to have a HX GTS 4 door (i was the second owner) and the fascia was black, my current HJ has a black fascia, another HX I looked at personally (said to be fully original) had a black fascia as well and most (but a couple) had a black fascia when i was looking to buy.
Is there any chance that they came out with the black fascia or have i been duped.
Also, some help please - The details of the car are as follows:
VIN 8Q69REL314406J
06/75 BHJ 27405A
MODEL HJ8W069 BODY I56462-A TRIM 1886-18X PAINT 506-5949 ENG L32 TRANS M40 AXLE GU7
I know the J on the end of the VIN means monaro. I also guess that it also started life as a 253 with an auto trans and was absinth yellow?
I spose my questions are:
Can anyone confirm it is a GTS? What colour was the trim originally? What does GU7 mean for the axle?
All your help would be appreciated.
Mark
I am not allowed a mistress so i got a GTS - and its better |
A GTS/4 is a monaro - so nuuur |
Hi HJ Heaven I may be wrong tho I think this is what your vin is VIN 8Q69REL314406J 8 Holden Q69 Monaro GTS R 253 E 1975 L3 Adelaide Assembly Plants 14406 Build number J HJ GU7 Salisbury 2.78:1 18X T Edited by user Friday, 29 August 2008 1:00:57 PM(UTC)
| Reason: Not specified |
If I agreed with you we`d both be wrong. |
Almost correct. L314406 is the plant sequence number (or PSN). The rest is spot on.
Hi All
Thanks One Tonner and HK1827 - much appreciated. You have laid my mind to rest.
Was that diff a LSD?
Mark
My original HJ GTS 4dr back in the 80s had the silver fascia 253 - trimatic - 2:78 LSD Cheers...Mario
My original HJ GTS 4dr back in the 80's had the silver fascia 253 - trimatic - 2:78 LSD Cheers...Mario
Not too sure about the HX, but the HJ GTS facia is definitely silver.
Cheers, Pete. Old Holdens never die, they just go faster. |
wow.. this car is absolutley identical to mine... right down to the trimatic and cloth inserts in the seats. what does the car look like at the moment? ive almost finished a resto on mine..
4/76 HJ monaroGTS |
4/76 HJ monaroGTS |
Hey RDS
They are pretty similar - see picture below.
I have looked at your rebuid thread with interest.
It looks like they are pretty much the same. Mine looks OK - good enough to drive around in but certainly not as well prepared as yours is.
Sorry, the picture didnt come through.
I ll try again.
[img]E:gts2[/img]
Sorry, the picture didn't come through.
I ll try again.
[img]E:gts2[/img]
One more go
[img]E:gts2[/img]
anyone know how to post a picture....
[img]C:\Documents and Settings\Administrator\Desktop[/img]
to post a picture.. 1. go to imageshack.us or join photobucket.com 2. clibck browse and find the picture you want to upload. select it n whatnot. 3. it should upload, and the page will refresh with a couple links to the pic. 4. select the link. will b |
4/76 HJ monaroGTS |
to post a picture.. 1. go to imageshack.us or join photobucket.com 2. clibck 'browse' and find the picture you want to upload. select it n whatnot. 3. it should upload, and the page will refresh with a couple links to the pic. 4. select the link. will |
4/76 HJ monaroGTS |
Yeah that was the one.
I was looking for a long time here in the west and nothing really came up.
I have put a bit into getting some work done on it and do now it drives pretty well but i like i said, i will take some time and get some other things |
