Joined: 2/03/2005(UTC) Posts: 491 ![Australia Australia]() Thanks: 3 times Was thanked: 8 time(s) in 8 post(s)
See if you can help??.... fitted a vs v6 and matching 700 into an fj body.... everything runs and works well except the computor will not turn on the thermatic fan....have been told I need a BCM to do this but surely there is an easier way (other than hot wire??) AL.
Hi gmholdman.
The engine cooling fan is switched by the engine ECU. The only thing you need a BCM for is to work the immobiliser. Considering that you already have it running, I assume youve had the VATS (immobiliser) removed from the mem-cal, so you w |
Hi gmholdman.
The engine cooling fan is switched by the engine ECU. The only thing you need a BCM for is to work the immobiliser. Considering that you already have it running, I assume you've had the VATS (immobiliser) removed from the mem-cal, so you |
The High/Low switching is done by the BCM.
The ECU simply tells it on/off and the BCM directs that signal, so Id rewire it to a simple on/off out of the ECU, and simply run the low speed windings off it, with the high speed hooked up to a dash switch t |
The ECU simply tells it 'on/off' and the BCM directs that signal, so I'd rewire it to a simple on/off out of the ECU, and simply run the low speed windings off it, with the high speed hooked up to a dash switc |
Hi Guys.
Yes, the high speed was on for high temp & a/cond together only. Just use the engine ECU to switch the cooling fan.
Dr Terry |
Terry, should have mentioned new VDO speedo and tacho not plugged in yet but temp and oil(vdo)are working ok. Can you see a problem with the speedo?? the auto elect seems to think the tacho may have some issues?? AL.
There's a purple wire (with a white stripe) that comes out of the 10 pin plug near the computer. That will hook up to most electronic speedos.
There is a tacho signal wire in the engine harness connector too. If you kept the original loom, there's |
Theres a purple wire (with a white stripe) that comes out of the 10 pin plug near the computer. That will hook up to most electronic speedos.
There is a tacho signal wire in the engine harness connector too. If you kept the original loom, theres 2 |
Thanks Mick and Terry, will pass the info on to my sparky and will print results but will not be for a month or so. Cheers AL.
