gmholdman Offline
#1 Posted : Saturday, 13 September 2008 8:43:28 PM(UTC)
gmholdman
See if you can help??.... fitted a vs v6 and matching 700 into an fj body.... everything runs and works well except the computor will not turn on the thermatic fan....have been told I need a BCM to do this but surely there is an easier way (other than hot wire??) AL.
#2 Posted : Sunday, 14 September 2008 7:15:37 AM(UTC)
Hi gmholdman.
The engine cooling fan is switched by the engine ECU. The only thing you need a BCM for is to work the immobiliser. Considering that you already have it running, I assume youve had the VATS (immobiliser) removed from the mem-cal, so you w
#3 Posted : Sunday, 14 September 2008 7:15:37 AM(UTC)
Hi gmholdman.
The engine cooling fan is switched by the engine ECU. The only thing you need a BCM for is to work the immobiliser. Considering that you already have it running, I assume you've had the VATS (immobiliser) removed from the mem-cal, so you
#4 Posted : Sunday, 14 September 2008 7:48:31 AM(UTC)
The High/Low switching is done by the BCM.
The ECU simply tells it on/off and the BCM directs that signal, so Id rewire it to a simple on/off out of the ECU, and simply run the low speed windings off it, with the high speed hooked up to a dash switch t
#5 Posted : Sunday, 14 September 2008 7:48:31 AM(UTC)
The ECU simply tells it 'on/off' and the BCM directs that signal, so I'd rewire it to a simple on/off out of the ECU, and simply run the low speed windings off it, with the high speed hooked up to a dash switc
#6 Posted : Sunday, 14 September 2008 7:22:14 PM(UTC)
Hi Guys.
Yes, the high speed was on for high temp & a/cond together only.
Just use the engine ECU to switch the cooling fan.
gmholdman Offline
#7 Posted : Monday, 15 September 2008 1:11:21 AM(UTC)
gmholdman
Terry, should have mentioned new VDO speedo and tacho not plugged in yet but temp and oil(vdo)are working ok. Can you see a problem with the speedo?? the auto elect seems to think the tacho may have some issues?? AL.
#8 Posted : Monday, 15 September 2008 2:13:11 AM(UTC)
There's a purple wire (with a white stripe) that comes out of the 10 pin plug near the computer.
That will hook up to most electronic speedos.
There is a tacho signal wire in the engine harness connector too.
If you kept the original loom, there's
#9 Posted : Monday, 15 September 2008 2:13:11 AM(UTC)
Theres a purple wire (with a white stripe) that comes out of the 10 pin plug near the computer.
If you kept the original loom, theres 2
gmholdman Offline
#10 Posted : Monday, 15 September 2008 5:50:45 AM(UTC)
gmholdman
Thanks Mick and Terry, will pass the info on to my sparky and will print results but will not be for a month or so. Cheers AL.
