GMH1975 Offline
#1 Posted : Tuesday, 30 September 2008 5:05:13 AM(UTC)
GMH1975
Hi guys i read a post on this forum once about holden part numbers ending in either odd or even numbers depending on weather they are a part that goes on the left or right side of a car.
I.E ................if i have a door lock with the part number 123 on it its a left side lock and i have another lock with a part number 124 its to suit the right side door.
Is this true and if so are odds left or right???????
Anyone who can understand this post want to coment??????
Not the BLOODY Kingswood
#2 Posted : Tuesday, 30 September 2008 6:05:22 AM(UTC)
correct left is odd, right is even
AFTER 1972 THERE AINT NO MUSCLE CARS AND MATCHING NUMBERS ARE FOR TIMES TABLES....
XY GTHO PH111 , now thats muscle...
GMH1975 Offline
#3 Posted : Tuesday, 30 September 2008 6:22:10 AM(UTC)
GMH1975
Thanks mate makes things a bit easier
#4 Posted : Tuesday, 30 September 2008 6:31:12 AM(UTC)
very easy to decipher GM numbers, Ford is even easier..
#5 Posted : Tuesday, 30 September 2008 7:04:20 AM(UTC)
It doesnt work this way with later parts, its simply consecutive from one side to the other as the numbers are issued, and it does not follow LH odd/RH even, or vice-versa.
For example:
VS front door shells:
LH: 92044858 (EVEN)
RH: 92044857 (ODD)
#6 Posted : Tuesday, 30 September 2008 7:09:28 AM(UTC)
ahhhhhh,mick.. that explains why i always order the wrong stuff lol, i should get with the times and stop livin in the 70s..lol
#7 Posted : Tuesday, 30 September 2008 7:34:12 AM(UTC)
Also doesnt work when parts swap sides. Example, front stubs off HK-HG swapped sides in HQ as the caliper moved from front to back.
If we all had the same (good) taste, who would buy all the Ford
GMH1975 Offline
#8 Posted : Tuesday, 30 September 2008 8:07:09 AM(UTC)
GMH1975
ive got 2 rear door central locking solinoids off a wb and will be fitting them in a hx and wanted to know which side is which
