#1 Posted : Wednesday, 8 October 2008 1:58:23 AM(UTC)
I have a Kingswood someone put a set of guages in but didnt connect up the Tacho, it has 2 connectors, brown and black marked,
do these go either side of the coil or how?
#2 Posted : Wednesday, 8 October 2008 4:34:13 AM(UTC)
Hi mate, i am not too sure if I can help you and I do not want to give you the wrong info.
But I just did the same to mine and I am certain tha the black is your earth and your brown went back to my distributor... but you might have old school set up. bu
#3 Posted : Wednesday, 8 October 2008 9:34:35 AM(UTC)
black ground ,dark brown coil...jim as per hq book
Jim in adelaide
#4 Posted : Wednesday, 8 October 2008 10:02:40 PM(UTC)
thanks for help but I tried that as that is similar to XU1 setup (black-earth and brown on points side of coil) but the tacho reads all over the place when I run motor so the Tacho must dodgey,
I have another guage set so I might take the tacho out and t
