hi all, just after some help. i have a vk wagon 6cyl-carb-auto. can get myself a vb sedan,for free,(v8-auto disc rear end-lowered)the body on the vb is shot. was thinking about engine swap into vk and swapping lowered suspension into my wagon.i know the engine swap will work,just not sure about legal side of it. as in older engine into newer car.also apart from fitting wagon brackets onto sedan diff,will the rear end fit? are there any other issues i might encounter. have been out of the car scene for a while due to family stuff. but am ready to get into it again. thanks for listening....cheers
VB is ADR27A, and VK is (I think) ADR27C, so you wont be able to do it by the letter of the law. Itll all fit though. If the VB is a 308 it may be a bit easier to get passed OK but you might have to get a few VK 308 bits like carby, dizzy etc to disguise |
thanks for the quick reply.the VB is 253. i wasnt aware that the diff for the 253 was the same as the 6 cyl.thanks for the info. not sure if i will do the engine swap yet,just a thought at the moment,as the V8 is in good nick and its free.plus im a V8 fan
i dont want to put a downer to your VB. i would leave it alone. if its a good motor but the body is gone. it really hasnt had a good life and been treated poorly. so its a good chance that the motor has had a hard life also like missed regular oil changes
The 6 cyl and 253 diffs are the same small salisbury but the uni joint yoke is bigger on the 253 diff.
If at first you dont succeed then skydiving is |
It may be a Borg Warner too if its a late VK 6cyl.
going in to the VK from VB put a ballast resistor in series with coil.
WANTED: QR 662xxx 1984 WB oyster crashpad 1x15x8 Cheviot armoulite HQ pair of 15" Dragway centrelines suit HQ |
thank u all for your responses and help. all input is much appreciated.i will try to reply to all. first:-hk1837,thanks again for your input, you have filled in a lot of gaps that i was unaware of. 2nd:-mikey,thank you for your concern, but i know the
