satanic customs Offline
#1 Posted : Saturday, 13 December 2008 12:18:22 PM(UTC)
satanic customs
Im sure this has been covered before, but here goes...
HQ pattern brakes on a HT. What's required?
Stub axle reversal, left for right etc
Custom brakes lines??? As reported in Xtreme Holdens mag?
What about booster and master cyl?
Rear end? Are hq Banjo axles the same length as HT ones? Is the rear end as easy as changing axles and brake drums??
Put it this way, if i had a driveable HJ kingy with disc front does this car have all i require to convert? Rotors etc
HK1837 Online
#2 Posted : Saturday, 13 December 2008 6:27:09 PM(UTC)
Front is as you describe, not sure about front brake lines.
HT booster and disc brake cylinder will be fine.
HT and HQ rear brajes are the same except fro stud pattern, but check the cylinder bore sizes first.
HQ axles wont fit in a HK-HG housing, so y
